Ribin
Not aware of any tools but key thngs to be aware of -
1) Make sure you have enough spare capacity in each site so that you have room for growth
2) Make sure you can summarise your class C's per site - if you do this well you should only need to advertise one address per site which has the following benefits -
i) much smaller routing tables
ii) any link within each site will not propogate between sites because the other sites only see the summarised address
iii) make sure any loopbacks etc. you use for management within each sites are contained with the summary address per site
Jon
