Configuring SGE2000P to use Cisco IP Phones
Answered Question
Sep 8th, 2010
Hello , I need to know if it's possible to configure the Cisco SGE2000P switch so I can use a Cisco 7945 IP Phone for Voice and Data.
The configuration is easy with other 3560 switches we got but, a colleague bought this switch to install it in a warehouse with 10 IP Phones and we cannot make it work with separate vlans (one for voice and one for data)
Any Ideas?
Thanks a lot.
Jose
Correct Answer by David Hornstein about 6 years 5 months ago
Hi Jose,
Considering there is not CDP within the switch itself,  you will probably have to tell the phones which VLAN they belong to.
I assume as a pre-requisite that the switch has configured both tagged and untagged vlans assigned to all ports, even the uplink ports.
Now assuming that is setup correctly, goto the phones themselves ;
1. press the settings button
2. unlock them with the keyboard command **#
3. set their Admin. VLAN Id to the tagged vlan number that is used for voice traffic.  You will have to find that option , most likely under the Network Configuration settings.
Save those changes. See if that makes a  difference.
regards Dave
Overall Rating: 5 (1 ratings)
Correct Answer
David Hornstein Thu, 09/09/2010 - 06:38
Hi Jose,
regards Dave
jbaraona Thu, 09/09/2010 - 08:50
Thanks for your help Dave, everything worked great!
best,
Jose
