Multichassis Multilink PPP Lab
Sep 8th, 2010
Hi.
I am trying to create a lab to set up MMP. I want to simulate a router with a bonded T1 connecting to 2 separate routers using MMP. See attached image. I have looked over the Cisco link for MMP (http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a008009408f.shtml) and I feel like I'm missing something. Anyone have any configuration suggestions?
David
Giuseppe Larosa Thu, 09/09/2010 - 03:42
Hello David,
in order to be able to perform multichassis multilink a direct link between the two routers RB and RC is needed ,as they need to use it to re-assembly PPP fragments for example.
>> High-latency WAN links between stack members, causing MP reassembly delays, may cause multichassis MP to be inefficient.
you need a LAN interface between RB and RC
Hope to help
Giuseppe
David Rosener Mon, 09/13/2010 - 13:56
OK. So I fiddled around with it a little more to get the configuration below.
Now what I can't figure out is a failover configuration for MMP. Say RouterB is hosting the bundle connection to RouterA. Any traffic going to RouterA is going through RouterB. If RouterB fails, I want RouterC to pick up the connection to RouterA. The only way I can get that to happen is if I disable and reenable the serial interface on RouterC (connected to RouterA).
Also, shouldn't MMP load-balance over both routers?
PS. I'm using HSRP to keep the ping going if I turn one of the routers off.
Related Content
