2651 only rings half the time on call transfer
Sep 8th, 2010
I have a 2561 with T1CAS. Incomming calls hit a call handler and are given the option to transfer direct to
an extension. When the transfer occurs, The calling party only hears half of the rings. The called party hears them all.
For example outside caller calls in and hears unity handler. They transfer to extension 1234. 1234 converage is to voicemail after about 22 seconds (4 rings.)
The caller will hear two rings with extended silence between the rings and the called party hears all 4 if they dont answer and let it roll to voicemail.
The behavior is the same if you call a DID number through this circuit and router and have them transfer you to a 4 digit extension, which removes
unity from the mix. If you call the handler or extension from the inside (VOIP) and repeat the transfer you dont get this behavior. So its gotta be
something on the gateway. Dial-peer perhaps? Any ideas?
byrne Wed, 09/08/2010 - 14:48
From the description it sounds like this is a h323 gateway to CUCM, correct?
The T1 CAS call would be considered answered (connected) when the call handler gets the call and gives the option to dial a extension, so after a transfer the gateway would not be playing the ringback, but this should be coming from CUCM Annunciator (ANN).
(Service Parameters  H225 Info for call Progress Tone --> Use ANN for Ring Back
Just a guess, but you may be running into CSCta10219  Intermittently silence packets streamed from MOH &/or ANN Server.
Rich
Greg Dowdy Thu, 09/09/2010 - 06:01
Its set up as MGCP. The current setting for H225 user message is User info for call progress tone. Will do some more looking.
byrne Thu, 09/09/2010 - 06:28
Since this is MGCP then the h225 setting is not relevant, and CUCM could be telling the gateway to play ringback on the transfer.
Can you please collected "debug mgcp packet" from the gateway for one on these calls.
Rich
Greg Dowdy Thu, 09/09/2010 - 06:44
Sep  9 13:41:17.729: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505562 [email protected] MGCP 0.1
N: [email protected]:2427
X: 0
O: DT/sup
Sep  9 13:41:17.777: MGCP Packet received from 10.22.96.12:2427--->
200 505562
Sep  9 13:41:17.785: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901365 [email protected] MGCP 0.1
X: 0
R: D/[0-9ABCD*#]
S: L/dl
Q: process,loop
Sep  9 13:41:17.789: MGCP Packet sent to 10.22.96.12:2427--->
200 7901365 OK
Sep  9 13:41:18.402: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505563 [email protected] MGCP 0.1
X: 0
O: D/3
Sep  9 13:41:18.438: MGCP Packet received from 10.22.96.12:2427--->
200 505563
Sep  9 13:41:18.442: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901367 [email protected] MGCP 0.1
X: 0
R: D/[0-9ABCD*#]
S:
Q: process,loop
Sep  9 13:41:18.446: MGCP Packet sent to 10.22.96.12:2427--->
200 7901367 OK
Sep  9 13:41:18.542: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505564 [email protected] MGCP 0.1
X: 0
O: D/7
Sep  9 13:41:18.566: MGCP Packet received from 10.22.96.12:2427--->
200 505564
Sep  9 13:41:18.674: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505565 [email protected] MGCP 0.1
X: 0
O: D/1
Sep  9 13:41:18.698: MGCP Packet received from 10.22.96.12:2427--->
200 505565
Sep  9 13:41:18.702: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901368 [email protected] MGCP 0.1
X: 0
R: D/[0-9ABCD*#]
S: L/dl
Q: process,loop
Sep  9 13:41:18.706: MGCP Packet sent to 10.22.96.12:2427--->
200 7901368 OK
Sep  9 13:41:18.814: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505566 [email protected] MGCP 0.1
X: 0
O: D/1
Sep  9 13:41:18.842: MGCP Packet received from 10.22.96.12:2427--->
200 505566
Sep  9 13:41:18.846: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901369 [email protected] MGCP 0.1
X: 0
R: D/[0-9ABCD*#]
S:
Q: process,loop
Sep  9 13:41:18.850: MGCP Packet sent to 10.22.96.12:2427--->
200 7901369 OK
Sep  9 13:41:18.943: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505567 [email protected] MGCP 0.1
X: 0
O: D/5
Sep  9 13:41:18.979: MGCP Packet received from 10.22.96.12:2427--->
200 505567
Sep  9 13:41:22.745: MGCP Packet received from 10.22.96.12:2427--->
CRCX 7901373 [email protected] MGCP 0.1
C: A000000002858553000000F5
X: 0
L: p:20, a:PCMU, s:off, t:b8
M: recvonly
R: DT/rel
Q: process,loop
Sep  9 13:41:22.761: MGCP Packet sent to 10.22.96.12:2427--->
200 7901373 OK
I: A033
v=0
c=IN IP4 10.21.6.2
m=audio 19522 RTP/AVP 0 100
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
Sep  9 13:41:22.785: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901374 [email protected] MGCP 0.1
X: 0
R: D/[0-9ABCD*#], DT/rel
S: G/rt
Q: process,loop
Sep  9 13:41:22.789: MGCP Packet sent to 10.22.96.12:2427--->
200 7901374 OK
Sep  9 13:41:22.805: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901375 [email protected] MGCP 0.1
X: 0
R: D/[0-9ABCD*#]
S: DT/ans
Q: process,loop
Sep  9 13:41:22.813: MGCP Packet sent to 10.22.96.12:2427--->
200 7901375 OK
Sep  9 13:41:22.841: MGCP Packet received from 10.22.96.12:2427--->
MDCX 7901376 [email protected] MGCP 0.1
I: A033
X: 0
M: sendrecv
R: D/[0-9ABCD*#], DT/rel, L/hf
S:
Q: process,loop
v=0
o=- 41011 0 IN EPN [email protected]
s=Cisco SDP 0
t=0 0
m=audio 30482 RTP/AVP 0
c=IN IP4 10.22.96.13
Sep  9 13:41:22.849: MGCP Packet sent to 10.22.96.12:2427--->
200 7901376 OK
Sep  9 13:41:29.284: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505568 [email protected] MGCP 0.1
X: 0
O: D/8
Sep  9 13:41:29.300: MGCP Packet received from 10.22.96.12:2427--->
200 505568
Sep  9 13:41:29.624: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505569 [email protected] MGCP 0.1
X: 0
O: D/2
Sep  9 13:41:29.708: MGCP Packet received from 10.22.96.12:2427--->
200 505569
Sep  9 13:41:29.913: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505570 [email protected] MGCP 0.1
X: 0
O: D/5
Sep  9 13:41:29.989: MGCP Packet received from 10.22.96.12:2427--->
200 505570
Sep  9 13:41:30.173: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505571 [email protected] MGCP 0.1
X: 0
O: D/1
Sep  9 13:41:30.289: MGCP Packet received from 10.22.96.12:2427--->
200 505571
Sep  9 13:41:32.750: MGCP Packet received from 10.22.96.12:2427--->
CRCX 7901395 [email protected] MGCP 0.1
C: A000000002858565000000F5
X: f
M: recvonly
R: DT/oc, DT/of
S: DT/sup(addr(7,2,3,0,7,9,8))
Q: process,loop
Sep  9 13:41:32.826: MGCP Packet sent to 10.22.96.12:2427--->
200 7901395 OK
I: A034
v=0
c=IN IP4 10.21.6.2
m=audio 16930 RTP/AVP 0 100
a=fmtp:100 192-194
Sep  9 13:41:33.535: MGCP Packet received from 10.22.96.12:2427--->
MDCX 7901398 [email protected] MGCP 0.1
I: A033
X: 0
M: recvonly
S:
Q: process,loop
Sep  9 13:41:33.543: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505572 [email protected] MGCP 0.1
X: 1
O: DT/sup
Sep  9 13:41:33.547: MGCP Packet sent to 10.22.96.12:2427--->
200 7901398 OK
Sep  9 13:41:33.563: MGCP Packet received from 10.22.96.12:2427--->
200 505572
Sep  9 13:41:33.571: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901401 [email protected] MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S: L/dl
Q: process,loop
Sep  9 13:41:33.579: MGCP Packet sent to 10.22.96.12:2427--->
200 7901401 OK
Sep  9 13:41:33.583: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901402 [email protected] MGCP 0.1
X: 0
S: L/ht
Q: process,loop
Sep  9 13:41:33.591: MGCP Packet sent to 10.22.96.12:2427--->
200 7901402 OK
Sep  9 13:41:34.152: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505573 [email protected] MGCP 0.1
X: 1
O: D/6
Sep  9 13:41:34.172: MGCP Packet received from 10.22.96.12:2427--->
200 505573
Sep  9 13:41:34.176: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901406 [email protected] MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S:
Q: process,loop
Sep  9 13:41:34.180: MGCP Packet sent to 10.22.96.12:2427--->
200 7901406 OK
Sep  9 13:41:34.292: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505574 [email protected] MGCP 0.1
X: 1
O: D/2
Sep  9 13:41:34.312: MGCP Packet received from 10.22.96.12:2427--->
200 505574
Sep  9 13:41:34.432: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505575 [email protected] MGCP 0.1
X: 1
O: D/1
Sep  9 13:41:34.452: MGCP Packet received from 10.22.96.12:2427--->
200 505575
Sep  9 13:41:34.456: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901407 [email protected] MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S: L/dl
Q: process,loop
Sep  9 13:41:34.460: MGCP Packet sent to 10.22.96.12:2427--->
200 7901407 OK
Sep  9 13:41:34.528: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901408 [email protected] MGCP 0.1
X: 0
S: G/rt
Q: process,loop
Sep  9 13:41:34.533: MGCP Packet sent to 10.22.96.12:2427--->
200 7901408 OK
Sep  9 13:41:34.565: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505576 [email protected] MGCP 0.1
X: 1
O: D/7
Sep  9 13:41:34.585: MGCP Packet received from 10.22.96.12:2427--->
200 505576
RQNT 7901409 [email protected] MGCP 0.1
X: 1
R: D/[0-9ABCD*#]
S:
Q: process,loop
Sep  9 13:41:34.589: MGCP Packet sent to 10.22.96.12:2427--->
200 7901409 OK
Sep  9 13:41:34.701: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505577 [email protected] MGCP 0.1
X: 1
O: D/1
Sep  9 13:41:34.721: MGCP Packet received from 10.22.96.12:2427--->
200 505577
Sep  9 13:41:34.729: MGCP Packet received from 10.22.96.12:2427--->
CRCX 7901411 [email protected] MGCP 0.1
C: A00000000285857c000000F5
X: 1
M: recvonly
R: DT/rel
Q: process,loop
Sep  9 13:41:34.745: MGCP Packet sent to 10.22.96.12:2427--->
200 7901411 OK
I: A035
v=0
c=IN IP4 10.21.6.2
m=audio 18788 RTP/AVP 0 100
a=fmtp:100 192-194
Sep  9 13:41:34.765: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901412 [email protected] MGCP 0.1
X: 1
S: G/rt
Q: process,loop
Sep  9 13:41:34.769: MGCP Packet sent to 10.22.96.12:2427--->
200 7901412 OK
Sep  9 13:41:34.817: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505578 [email protected] MGCP 0.1
X: f
O: DT/oc(dt/sup)
Sep  9 13:41:34.837: MGCP Packet received from 10.22.96.12:2427--->
200 505578
Sep  9 13:41:34.893: MGCP Packet received from 10.22.96.12:2427--->
MDCX 7901413 [email protected] MGCP 0.1
I: A034
X: f
M: sendrecv
S:
v=0
o=- 41012 0 IN EPN [email protected]
s=Cisco SDP 0
t=0 0
m=audio 25804 RTP/AVP 0
c=IN IP4 10.21.6.66
Sep  9 13:41:34.905: MGCP Packet sent to 10.22.96.12:2427--->
200 7901413 OK
Sep  9 13:41:45.314: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505579 [email protected] MGCP 0.1
X: 2
O: DT/sup
Sep  9 13:41:45.363: MGCP Packet received from 10.22.96.12:2427--->
200 505579
Sep  9 13:41:45.383: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901439 [email protected] MGCP 0.1
X: 2
R: D/[0-9ABCD*#]
S: L/dl
Q: process,loop
Sep  9 13:41:45.387: MGCP Packet sent to 10.22.96.12:2427--->
200 7901439 OK
Sep  9 13:41:45.923: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505580 [email protected] MGCP 0.1
X: 2
O: D/6
Sep  9 13:41:45.940: MGCP Packet received from 10.22.96.12:2427--->
200 505580
Sep  9 13:41:45.948: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901445 [email protected] MGCP 0.1
X: 2
R: D/[0-9ABCD*#]
S:
Q: process,loop
Sep  9 13:41:45.952: MGCP Packet sent to 10.22.96.12:2427--->
200 7901445 OK
Sep  9 13:41:46.064: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505581 [email protected] MGCP 0.1
X: 2
O: D/2
Sep  9 13:41:46.084: MGCP Packet received from 10.22.96.12:2427--->
200 505581
Sep  9 13:41:46.192: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505582 [email protected] MGCP 0.1
X: 2
O: D/1
Sep  9 13:41:46.212: MGCP Packet received from 10.22.96.12:2427--->
200 505582
Sep  9 13:41:46.216: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901446 [email protected] MGCP 0.1
X: 2
R: D/[0-9ABCD*#]
S: L/dl
Q: process,loop
Sep  9 13:41:46.220: MGCP Packet sent to 10.22.96.12:2427--->
200 7901446 OK
Sep  9 13:41:46.332: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505583 [email protected] MGCP 0.1
X: 2
O: D/1
Sep  9 13:41:46.352: MGCP Packet received from 10.22.96.12:2427--->
200 505583
Sep  9 13:41:46.356: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901447 [email protected] MGCP 0.1
X: 2
R: D/[0-9ABCD*#]
S:
Q: process,loop
Sep  9 13:41:46.360: MGCP Packet sent to 10.22.96.12:2427--->
200 7901447 OK
Sep  9 13:41:46.464: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505584 [email protected] MGCP 0.1
X: 2
O: D/6
Sep  9 13:41:46.480: MGCP Packet received from 10.22.96.12:2427--->
200 505584
Sep  9 13:41:46.488: MGCP Packet received from 10.22.96.12:2427--->
CRCX 7901448 [email protected] MGCP 0.1
C: A00000000285859d000000F5
X: 2
M: recvonly
R: DT/rel
Q: process,loop
Sep  9 13:41:46.504: MGCP Packet sent to 10.22.96.12:2427--->
200 7901448 OK
I: A036
v=0
c=IN IP4 10.21.6.2
m=audio 16544 RTP/AVP 0 100
a=fmtp:100 192-194
Sep  9 13:41:46.528: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901449 [email protected] MGCP 0.1
X: 2
S: G/rt
Q: process,loop
Sep  9 13:41:46.532: MGCP Packet sent to 10.22.96.12:2427--->
200 7901449 OK
Sep  9 13:41:47.907: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901450 [email protected] MGCP 0.1
X: 0
S:
Q: process,loop
Sep  9 13:41:47.911: MGCP Packet sent to 10.22.96.12:2427--->
200 7901450 OK
Sep  9 13:41:48.003: MGCP Packet received from 10.22.96.12:2427--->
MDCX 7901451 [email protected] MGCP 0.1
I: A033
X: 0
M: sendrecv
S:
Q: process,loop
v=0
s=Cisco SDP 0
t=0 0
m=audio 29766 RTP/AVP 0
c=IN IP4 10.21.6.51
Sep  9 13:41:48.015: MGCP Packet sent to 10.22.96.12:2427--->
200 7901451 OK
Sep  9 13:41:49.594: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505585 [email protected] MGCP 0.1
X: 1
O: DT/rel(0)
Sep  9 13:41:49.614: MGCP Packet received from 10.22.96.12:2427--->
200 505585
Sep  9 13:41:49.618: MGCP Packet received from 10.22.96.12:2427--->
DLCX 7901454 [email protected] MGCP 0.1
I: A035
X: 1
Sep  9 13:41:49.626: MGCP Packet sent to 10.22.96.12:2427--->
250 7901454 OK
P: PS=0, OS=0, PR=0, OR=0, PL=0, JI=65, LA=0
Sep  9 13:41:49.646: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901455 [email protected] MGCP 0.1
X: 1
R: DT/sup, D/[0-9ABCD*#]
S: DT/rlc
Q: process,loop
Sep  9 13:41:49.654: MGCP Packet sent to 10.22.96.12:2427--->
200 7901455 OK
Sep  9 13:41:49.874: MGCP Packet received from 10.22.96.12:2427--->
MDCX 7901456 [email protected] MGCP 0.1
I: A033
X: 0
M: recvonly
S:
Q: process,loop
Sep  9 13:41:49.878: MGCP Packet sent to 10.22.96.12:2427--->
200 7901456 OK
Sep  9 13:41:49.902: MGCP Packet received from 10.22.96.12:2427--->
DLCX 7901457 [email protected] MGCP 0.1
I: A033
X: 0
R: DT/rlc
S: DT/rel
Q: process,loop
Sep  9 13:41:49.910: MGCP Packet sent to 10.22.96.12:2427--->
250 7901457 OK
P: PS=588, OS=94080, PR=505, OR=80482, PL=0, JI=63, LA=0
Sep  9 13:41:50.227: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505586 [email protected] MGCP 0.1
X: f
O: DT/ans
Sep  9 13:41:50.247: MGCP Packet received from 10.22.96.12:2427--->
200 505586
Sep  9 13:41:50.251: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901458 [email protected] MGCP 0.1
X: f
S:
Q: process,loop
Sep  9 13:41:50.255: MGCP Packet sent to 10.22.96.12:2427--->
200 7901458 OK
un
Sep  9 13:41:54.882: MGCP Packet sent to 10.22.96.12:2427--->
NTFY 505587 [email protected] MGCP 0.1
X: 0
O: DT/rlc
Sep  9 13:41:54.902: MGCP Packet received from 10.22.96.12:2427--->
200 505587
Sep  9 13:41:54.906: MGCP Packet received from 10.22.96.12:2427--->
RQNT 7901470 [email protected] MGCP 0.1
X: 0
Q: process,loop
Sep  9 13:41:54.947: MGCP Packet sent to 10.22.96.12:2427--->
200 7901470 OK
all
All possible debugging has been turned off
mwvgw1#
Greg Dowdy Thu, 09/09/2010 - 07:04
version 12.3
hostname mwvgw1
boot-start-marker
boot system flash c2600-ipvoice-mz.123-11.T2.bin
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $
username
network-clock-participate wic 0
no network-clock-participate wic 1
voice-card 0
dspfarm
no local-bypass
aaa new-model
aaa group server tacacs+ ACS
server 10.20.1.110
aaa authentication login
aaa authentication enable default group ACS enable none
aaa authorization commands
aaa accounting exec lourdes start-stop group ACS
aaa accounting commands
aaa session-id common
ip subnet-zero
ip cef
ip multicast-routing
no ftp-server write-enable
voice translation-rule 1
rule 1 /62/ /8/
voice translation-profile srst1
translate calling 1
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.22.96.11
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.22.96.11
ccm-manager config
controller T1 0/0
framing sf
linecode ami
cablelength short 133
ds0-group 1 timeslots 1-16 type e&m-wink-start
controller T1 0/1
framing esf
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 0/2
framing esf
linecode b8zs
interface Multilink1
ip address 10.21.250.5 255.255.255.252
ip pim sparse-dense-mode
ppp multilink
ppp multilink group 1
interface MFR1
no ip address
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description ***MARCUMDATA***
encapsulation dot1Q 10
ip address 10.21.2.5 255.255.255.0
standby 1 ip 10.21.2.1
standby 1 priority 150
standby 1 preempt
standby 1 track Multilink1 100
interface FastEthernet0/0.11
encapsulation dot1Q 11
ip address 10.21.6.2 255.255.255.0
ip helper-address 10.21.2.2
standby ip 10.21.6.1
standby priority 150
standby preempt
standby track Multilink1 100
interface FastEthernet0/0.12
description **** Marcum SleepLab Network ****
encapsulation dot1Q 12
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1:0
no ip address
encapsulation ppp
ppp chap hostname group1
ppp multilink
interface Serial0/2:0
no ip address
encapsulation ppp
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 10.21.250.6
ip route 10.0.0.0 255.0.0.0 10.21.250.6
ip route 10.20.9.0 255.255.255.0 10.21.2.3
ip route 10.21.2.15 255.255.255.255 10.20.1.61
ip route 10.21.250.0 255.255.255.252 10.21.6.3
ip http server
logging source-interface FastEthernet0/0.11
access-list 109 deny tcp host 10.21.6.86 any eq 2000
access-list 109 permit ip any any
snmp-server community lourdesmon RW
snmp-server community lourdesmon1 RW
snmp-server enable traps tty
tacacs-server host 10.20.1.110
tacacs-server directed-request
control-plane
call application alternate DEFAULT
voice-port 0/0:1
mgcp
mgcp call-agent 10.22.96.12 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0.11
mgcp bind media source-interface FastEthernet0/0.11
mgcp profile default
dial-peer voice 99900199 pots
application mgcpapp
port 0/0:1
dial-peer voice 9 pots
destination-pattern 9[2-9]......
forward-digits 7
prefix 606
dial-peer voice 606 pots
destination-pattern 606.......
forward-digits all
dial-peer voice 91 pots
destination-pattern 91..........
forward-digits 11
dial-peer voice 9911 pots
destination-pattern 9911
forward-digits 3
call-manager-fallback
max-conferences 4
limit-dn 7940 1
ip source-address 10.21.6.2 port 2000 strict-match
max-ephones 48
max-dn 192 preference 2
dialplan-pattern 1 62... extension-length 4 extension-pattern 8...
alias 1 32115 to 8107 preference 1 cfw 8202 timeout 10
alias 2 37706 to 8220
translation-profile incoming srst1
byrne Thu, 09/09/2010 - 14:25
Don't see where there should be a issue with the caller on the T1 CAS side hearing ringback tone when the call gets transfer.
I see the call come in and goes to 37115, connects to Unity I am guessing 10.22.96.13.
User hits 8251, call gets transfer to 10.21.6.51
Call Manager is telling the t1 CAS GW to play ringback from 13:41:34.528 to 13:41:48.003, there should not be any /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} interruptions of ringback between these times.
Is this when the issue is seen (heard)?
Greg Dowdy Fri, 09/10/2010 - 06:14
Thats what is strange. You have the  sequence  correct. The problem comes in when User hits 8251, call gets transfer to 10.21.6.51.
8251 extension has a coverage path to voicemail and the time to coverage is 25 seconds, about 4 and a half rings.
On the caller side, they only hear half the rings. On the called party side, they get (1) ring silence (2)  ring silence (3) ring silence (4)ring silence partial ring and xfer to voicemail.
The incomming caller hears (1) ring silence silence (2) ring silence silence then transfer to voicemail. In other words, they only hear half the ringbacks they are supposed to.  The caller is perceving that the ring time is too short when it really isnt.You can set the time to voicemail to 50 seconds and the pattern repeats, just longer.
We had one a few years ago where you got no ringback at all, but that was fixed by modifying the incoming dial peer and adding a statement that allowed the gateway to recognize a different proress indicator coming from the phone company . That was on CM 4.3. This one works fine, but you only hear half the rings when you call through this gateway and transfer.
byrne Fri, 09/10/2010 - 10:20
Think you are most likely running into a old bug:
CSCef60201 No ringback on transfer, Cadence3 off timer set to 10000
Symptom:
Ringback cadence is extremely long when transferring calls using MGCP. The ringback cadence is 16 seconds between rings.
Problem:
The Cadence3 timer is set to 10000ms causing the ring cadence to be 2 seconds on and 14 seconds off
Workaround:
Manually change the c:\program files\cisco\tftpath\united_states\gateway_tones.xml file. Change the "CPTONE_RING_BACK" section, "ONTT" parameter to 1.
Then enable the 3700 to download the gateway tones with the 'ccm-manager download-tones'.
This will set the cadence 3 tone to 1 ms and thereby avoid the 10000 ms default.
This workarond has not been fully tested, but my solve the problem.
View on cisco.com here:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCef60201
Fixed-In  12.3(11)T8 and above.
