Two tunnels pointing to one loopback IP address
Sep 8th, 2010
We recently had an issue with a routing configuration running EIGRP with 2 tunnels pointing to the same loopback IP. The router went down due a power outage and failover didn't work. Is it possible to have 2 tunnels point to the same loopback, if not, would that cause the failover not to work properly?
jcozzupoli Wed, 09/08/2010 - 14:41
Hi,  Could you please attach some kind of topology diagram and any configs you are able to share as well as your explaination doesn't entirely give the whole picture for anyone to help you with.  Cheers, Joe
Posted from my mobile device.
