UCCX Best Practice - UCM Agent Line Configuration documentation
Answered Question
Sep 8th, 2010
  • Silver, 250 points or more
With UCCX, I have always abided by some rules when it came to configuration of the agent's line in CUCM.  At least to be a TAC supported solution anyway.  For Example:
1. Agent Extension can not be shared
2. Agent Exension not part of any CUCM hunt group or call pickup group
3. Call Waiting Disabled Max/Busy 2/1
4. Agent Extension should not take inbound calls
5. Agent extensions not set to CFNA
6. etc....
I had someone ask me to back this up with some sort of documentation.  I reviewed the UCCX 7.x SRND and could not find anywhere explicitly talking about CUCM configuration.
Does anyone know if this type of information is documented?
Thanks in advance,
Shane
Correct Answer by William Bell about 6 years 9 months ago
Shane,
Look at the release notes for your version of UCCX. They typically have a
section called "Unsupported Features in Unified CM". There is also a
section on "Unsupported and Supported Actions" and general "Unsupported
Configurations in Cisco Unified CCX".
Release notes URL:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/prod_release_note...
st.html
You won't find the data in the SRND for whatever reason.
HTH.
Bill
Please remember to rate helpful posts.
On 9/8/10 5:40 PM, "shane.orr"
Overall Rating: 5 (3 ratings)
Correct Answer
William Bell Wed, 09/08/2010 - 14:57
  • Purple, 4500 points or more
Shane,
Release notes URL:
st.html
HTH.
Bill
shane.orr Wed, 09/08/2010 - 15:14
Thanks man, you hit the nail on the head.
Or at least that is the best documented answer I am going to get.  I did not think about looking in the release notes for that type of info.
