H323 Block call on ANI
Answered Question
Sep 8th, 2010
Currently I have the a inbound translation pattern which translates the called number from 10 to 6.  Translation profile which is applied as imcoming to the pots dial peer is .
I need to block a few numbers based on originating ANI.  I have made new translation rules to reject the numbers, and they do work.
Can I have a translate called, and a translate calling  on the same profile / dial peer.
Voice translation-rule 12
rule 1 /41625\(.....\)/ /1\1/
Voice translation-rule 13
rule 1 reject /^(10 digit number)/
Voice translation-profile XXXX
translate calling 13
translate called 12
Is this possible?  Thanks
Correct Answer by William Bell about 6 years 8 months ago
You can have translate called and calling directives on the same translation
profile. Though, I think that when you are doing a call rejection this
configuration approach doesn't apply. I block calls using the "call-block"
command under the pots dial-peer. This is evaluated independently of a
translation. Or at least that is my understanding.
HTH.
Bill
On 9/8/10 5:44 PM, "balitewiczp"
Overall Rating: 5 (3 ratings)
Correct Answer
William Bell Wed, 09/08/2010 - 15:02
  • Purple, 4500 points or more
HTH.
Bill
balitewiczp Thu, 09/09/2010 - 06:36
Thanks for the info and quick response.  Using called blocking command worked very nicely.
