Is possible to split a fiber conneciton between two seperate networks
Answered Question
I never heard of this but wanted to ask some experts.  A security company spoke to the owner of our company today about implementing IP Cameras.  These cameras would have their own switches in the wiring closets, but need a fiber connection back to our server room.  He said that it is possible to split the fiber connection so the two seperate networks can share the fiber backbone.
Is this possible?  Do they use different frequencies?  If this is possible how does this affect bandwidth?
Correct Answer by Leo Laohoo about 6 years 10 months ago
Thanks for the ratings.
DWDM/CWDM is like a two-edged sword.  For a small fee (the procurement of the modules and the circulator) you can split/splice one physical fibre optic cable into multiple pairs.  The downside is that once you loose your one-and-only fibre link (to a cable-hunting-buck-hoe) then you're in trouble.
It's called Coarse Wave Division Multiplex (CWDM) or Dense Wave (DWDM).
Cisco Dense Wavelength-Division Multiplexing Small Form-Factor Pluggable Module
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6576/product_data_sheet0900aecd80582763.html
Cisco CWDM GBIC and SFP Solution
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6575/product_data_sheet09186a00801a557c_ps4999_Products_Data_Sheet.html
Cisco Enhanced Wavelength Division Multiplexing Product Line
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/product_data_sheet0900aecd806a1c36.html
Is this what you are looking for?
Please don't forget to rate our useful posts.  Thanks.
Overall Rating: 5 (2 ratings)
Correct Answer
Leo Laohoo Wed, 09/08/2010 - 17:44
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Correct Answer
Leo Laohoo Wed, 09/08/2010 - 18:43
  • Hall of Fame,
    2017 LAN, Wireless
Sounds like really cool technology but perhaps over kill for what we need.  We only need to about two 500 foot runs inside of a warehouse and office.  Not sure why the guy suggested this technology, to me it sounds cheaper to run two new fiber lines for the security system.  This equipment sounds pretty expensive.  Is this mostly used for single mode fiber?
Leo Laohoo Wed, 09/08/2010 - 19:30
  • Hall of Fame,
    2017 LAN, Wireless
It's only long reach because the philosophy is it's cheaper to use DWDM/CWDM for long distance than putting a second pair of fibre in.
If it's short reach, then I'd recommend that you put MORE THAN what you need.  I don't know if you are aware, when we are talking about the cost of laying down fibre (whether it's long or short reach) the cost of the fibre cable alone is constant but the labour cost is insidious.  So in your case, for example, if you need only one more pair, then put a 3 pair or 6 pair fibre optic.
