help needed for connecting cme to IPC alliance system
Sep 8th, 2010
Hi guys, i'm trying to implement this design but failed. Please help me to clarify what had went wrong.
I have a running CME 4.0 and it is working fine. What i'm going to do is pass 2 dn to IPC Alliance system. Due to insufficient card slot, I've purchased another router with VWIC-1MFT. The problem is controller E1 that i've configured in router B wont establish (down). I'm using 1-2,4-5 connector and I've tried with loopback test on router and it works fine.
router A (forward the 2 dn to router B)
dial-peer voice 6666 voip
description **forward to voice_gw**
destination-pattern 6666
session target ipv4:192.168.10.3
dial-peer voice 6600 voip
destination-pattern 6600
sh dial-peer voice summary
6666   voip  up   up             6666               0  syst ipv4:192.168.10.3
6600   voip  up   up             6600               0  syst ipv4:192.168.10.3
router B (grab dn from router A and pass them to IPC)
clock timezone MY 8
network-clock-participate wic 0
voice-card 0
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-2 type e&m-melcas-immed
voice-port 0/0/0:1
dial-peer voice 6600 pots
port 0/0/0:1
prefix 6600
dial-peer voice 6666 pots
port 0/0/0:1
prefix 6666
sh controller e1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Cablelength is Unknown
  Transmitter is sending remote alarm.
  Receiver has loss of frame.
  alarm-trigger is not set
  Version info Firmware: 20090408, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (120 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 120 Unavail Secs
  Total Data (last 3 15 minute intervals):
     17020 Line Code Violations, 24 Path Code Violations,
     4 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     4 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2650 Unavail Secs
Felipe Garrido Wed, 09/08/2010 - 07:41
  • Cisco Employee,
Does the IPC system need to be connected with a straigth or cross-over E1/T1 cable? If cross-over, the pin out is 1-4 2-5. It's worth a try if you can make the cable. Also, check the framing and line code configuration and make sure they match with the IPC system.
-Felipe
limsiangchin Wed, 09/08/2010 - 18:48
yes it is using the crossover cable, framing and linecode is match as well. i was thinking whether the setup shouldnt be done this way  or there is a better way to do this using same hardwares.
Felipe Garrido Thu, 09/09/2010 - 08:28
  • Cisco Employee,
Is the pinout for the cross-over cable 1-4 2-5?
-Felipe
Mohamed Shameer... Wed, 04/24/2013 - 08:56
Did you manage to integrate CME with IPC alliance system
if yes, can you please share some configuration steps
shameer
