Swx 3750 TCAM utilization
Sep 8th, 2010
I have a 3750 IOS 12.2. I have configured a lot of access lists on it as i am using it instead of a firewall. The issue is that the for show platform tcam utilization the size for security/access list table has reached 97 %. 1000/1024.
How can i resolve this issue? What will be best workaround in this situation. This L3 switch has lot of servers behind it and still i have requirements for more ACL.
Also what will happen when the TCAM table reached to it max i.e; 1024?
vragotha Thu, 09/09/2010 - 01:07
  • Silver, 250 points or more
You can change the SDM template to get more ACEs supported. The Access SDM template maximizes ACL usage and gives a limit upto 2k ACEs
Configure 'sdm prefer access' and reload the box
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swsdm.html
If you need to have more ACEs then you may have to consolidate the ACLs or upgrade hardware, or simply split up the ACLs between this device and others.
