C870 - 2 ISP Nat do not witching automatically
pwolsza_wolfik1
I have made configuration for 2 ISP.
Unfortunately NAT do not want to switch automatically from inactive to active route.
Any suggestions:
My config:
interface  FastEthernet0
interface  FastEthernet1
interface  FastEthernet2
interface  FastEthernet3
description WAN2
switchport access vlan 2
interface FastEthernet4
description  $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address 10.14.62.83 255.255.255.248
no ip  redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip  virtual-reassembly
duplex auto
speed auto
interface Vlan1
description  $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address  192.168.9.1 255.255.255.0
no ip redirects
no ip unreachables
no ip  proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
interface  Vlan2
ip address 192.168.11.2 255.255.255.0
no ip redirects
no ip  unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip  forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.14.62.81
ip route  0.0.0.0 0.0.0.0 192.168.11.1 2
ip http server
ip http authentication local
ip http  secure-server
ip  http timeout-policy idle 60 life 86400 requests 10000
ip nat  inside source route-map ISP1 interface FastEthernet4 overload
ip nat  inside source route-map ISP2 interface Vlan2 overload
logging trap  debugging
access-list  101 permit ip 192.168.9.0 0.0.0.255 any
access-list 102 permit ip  192.168.9.0 0.0.0.255 any
no cdp run
route-map ISP2 permit 10
match ip address 102
set ip  next-hop 192.168.11.1
route-map ISP1 permit 10
match ip address 101
set ip  next-hop 10.14.62.81
5 Replies 5
Giuseppe Larosa
Hello Pwolza,
try to match the outgoing interface in order to have second route-map to kick in
match interface fas4
match interface vlan2
in second route-map
Hope to help
Giuseppe
Well with a litle of your help I made some corrections to the configuration and now it working
no cdp run
route-map ISP2 permit 11
match interface Vlan2
match interface FastEthernet4
continue 11
Hello Pwolza,
I'm happy it is working now I had little time so I had given you just an hint and you have been good to take it.
Note:
these are actually two different route-maps (they have different names) and not two blocks of the same route-map.
So the continue 11 does not provide a reference to the other route-map but to block 11 in route-map ISP1.
My guess is that without the continue 11 line the behaviour should not change as the meaning of match interface should be "match the outgoing interface to be used to send traffic".
Hope to help
Giuseppe
Yes, indeed it is working without continue 11.
Thanks for suggestion.
Now everything works fine.
Unfortunately the automatically switching of the  ISP only works when I will put off the plug from the cisco socket.
When the signal goes down from ISP  router, CISCO do not want to push the traffic into backup ISP.
Tracert gives me information of the destination IP for  example cisco.com but without addresses of hoops.
What to do now ??
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
