09-08-2010 10:36 PM - edited 03-11-2019 11:37 AM
I am pretty new with ASA and have the following questions :-
1. What is the way to see logs via the ASDM ? and how do we create a filter to view the logs filtering it via IP address ?
2. If the logs were to be viewed on the CLI, what is the way to view the logs and to filter the IP based on IP address ?
Any good URLs would be appreciated.
Thank you,
Cheers,
- SN -
Solved! Go to Solution.
09-08-2010 11:59 PM
>>Open ASDM---goto-->Monitoring----Under Logging go to Real Time Log viewer/Log Buffer----->Filter By IP address
For details: http://www.cisco.com/en/US/docs/security/asa/asa80/asdm60/user/guide/cfglog.html
Enable logging on buffer and then search for specific logg, example
logging on
logging buffered 7
ASA2(config)# sh logg | inc 192.168.165.3
Sep 09 2010 12:29:08: %ASA-6-302020: Built inbound ICMP connection for faddr 10.78.167.123/512 gaddr 192.168.165.3/0 laddr 192.168.165.3/0
hope this helps
09-08-2010 11:59 PM
logging on
logging buffered 7
hope this helps
