Showing results forĀ
Search instead forĀ
Did you mean:Ā
Do ISL trunking supports Native vlan?
mahesh18
Level 6
Level 6
Hi all,
i know 802.1q trunking supports native lan but need to make sure that if ISL trunking  supports native vlan or  not?
thanks
mahesh
2 Accepted Solutions
Giuseppe Larosa
Hello Mahesh,
ISL has no native vlan concept because it places the whole ethernet frame in the payload of an ISL frame
native Vlan is an 802.1Q specfic feature/concept
Hope to help
Giuseppe
Jon Marshall
Mahesh
Just to add to Giuseppe's post -
ISL is Cisco proprietary unlike 802.1q. Because of this ISL does not need a native vlan because by definition you would need to have an all cisco network if you wanted to run ISL on your switches. So every switch would be capable of supporting PVST (Per vlan spanning tree). PVST is Cisco proprietary as well.
802.1q is an IEEE standard and because of this it needs to interoperate with switches that may not run PVST and hence the need for the native vlan ie. the vlan that is not tagged on a trunk link.
Jon
Giuseppe Larosa
Hello Mahesh,
Hope to help
Giuseppe
Hi Jon and guislar,
Many thanks for reply
Mahesh
Jon Marshall
Mahesh
Jon
