madathilsiva Thu, 09/09/2010 - 04:30
As i understud now, there is no CLI  in CE 500 switch. So how can we do the port security in this switch?
Please help......................
josue jonathan ... Fri, 04/20/2012 - 07:18
Hi !!!
i try change the configuration the port in the switch catalyst express 500, i need disable switchport port-security, a try with http://10.1.1.1/exec (IP the sw CE500) and save configuration with wr command, if a check the configuration de port is correct but i reboot the switch and check the configuration the port appear the switchport port-security configuration again.
do you know solve this??
thk and regards!!!
