Fax to Email on UC560 w PRI
Sep 9th, 2010
I would like to give the 40 users on a customers UC560, a seperate DID for calls and Faxes.  Faxes would go to email, as well as voicemail.  The DIDs for voice go to email without a problem.  Can I associate the second DID (for Fax) to the same mailbox for fax?  I have utilized T37 for FXS but this is a little different.
chris unger Fri, 09/10/2010 - 10:51
I set the fax number in CUE, but it just goes to busy.  Do I need to have the number translated somewhere else?  I'm using two distinct numbers one for voice and one for the users personal fax.  I have searched up and down for a document that gives some detail.
Thanks again@!!!
chris unger Fri, 09/10/2010 - 12:15
OK, I think I'm down to getting the voice commands right.  Just to rehash what I have...  40 users with seperate DIDs and Fax numbers from a PRI.  Here is what I think I need to do, but have a few questions:
dial-peer voice 2500 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 5555555555
information-type fax
session target mailto:[email protected] voice 3000 pots
description FAX
translation-profile incoming FAX_Called_4
service onramp
incoming called-number 5555555555
dial-peer
direct-inward-dial
port 0/2/0:23
Do I need a seperate dial-peer voice xxxx MMOIP command for each users fax number?
Do I need a seperate voice xxxx pots command for each users fax number?
just to be clear of my "code" 801 is the users DID vm box, 5555555555 is the users private fax number
Brandon Buffin Fri, 09/10/2010 - 13:29
Chris,
     I think you're on the right track. Yes, you will need a separate MMOIP dial peer for each DID. Your need for multiple inbound POTS dial peers will depend on your DIDs, If you have DIDs 555-555-5550 - 555-555-5559, you can use one dial peer:
dial-peer voice 1 pots
incoming called-number 555555555.
direct-inward-dial
port 0/2/0:23
If you have DIDs 555-555-5551, 555-555-5523 and 555-555-5599, you will need separate dial peers.
Hope this helps.
Brandon
