Webvpn Robots.txt file
Sep 9th, 2010
We have an ASA 5510 running IOS 8.2.1. In this ASA we have a WebVpn configured (clientless ssl). We need to avoid Google from showing our WebVpn URL on the result search. For this, Google has asked us to add a line on our robots.txt file, for them to be sure that the device and the WebVpn is ours.
The thing is that if we try and see the robots.txt file we get this result,
User-agent: * Disallow: /
Does anyone know how to edit this file or where to find it?
Thanks a lot !
pcristina Thu, 09/09/2010 - 12:13
Hi Yudong,
Thank you very much for your answer. The thing is that I dont know were to find the Robots.txt file in the ASA. That was my doubt.
Thanks!
Yudong Wu Thu, 09/09/2010 - 12:27
  • Gold, 750 points or more
I don't think you can access this robots.txt file on ASA to edit it.
We just put the following context in it, which does not allow google to do the index and something like that.
User-agent: *
Disallow: /
