sistemas.sede Thu, 09/09/2010 - 07:35
Hi Mike,
If I'm right, with the reload command I can schedule a specific reboot, for a specific day, but what I need is that ASA reloads the same day-hour every week, not only once.
Thanks.
mirober2 Thu, 09/09/2010 - 07:37
  • Cisco Employee,
Hi Antonio,
In that case, the ASA doesn't support a feature that would accomplish this for you. You could look into setting up an Expect script that you can run on a PC with cron to login to the ASA and schedule a reload on a weekly basis.
Hope that helps.
-Mike
Panos Kampanakis Thu, 09/09/2010 - 11:35
  • Cisco Employee,
To add to mrober2's answer, you can also use simple SecureCRT vbscript to do that. You can find many examples on-line.
I hope it helps.
PK
