PCM Capture
Answered Question
Does anyone know if it is possible for a user to initiate a PCM capture? I recall a TAC engineer telling me that you could configure this and have the users punch *** on their keypad while on a call that we would like to get a PCM capture for. I've looked around quite a bit and can't find a procudure for this. Is this possible or was the engineer mistaken?
-Jake
Correct Answer by Steven Holl about 6 years 5 months ago
The '***' script is something which a colleague of mine wrote ad-hoc to facilitate in getting captures for intermittent issues.
I am attaching the latest version of the script and the instruction steps for this.  I need to make this very clear: this is not a TAC/BU supported script.  You may run into stability or reliability issues with it.  It's proven stable in the environments which we've used it, but because it was built off-the-cuff, it won't ever go through regression testing and we can't guarantee behavior.
Note that the tool to extract the PCM capture binary to audio streams is TAC internal, so you will need to open an SR to get the capture converted to listenable audio streams.
Overall Rating: 5 (2 ratings)
Adrian Saavedra Thu, 09/09/2010 - 09:19
Search Netpro for a PDF document entitled: Using ‘show call active voice brief’ to Track and Troubleshoot Voice Calls. You'll find some threads where you can download this nice document explaining PCM Capture procedure used by TAC.
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
Correct Answer
Steven Holl Thu, 09/09/2010 - 11:06
