Quad SUP VSS how to add redundant Supervisories
Sep 9th, 2010
I have a VSS 1440 System running under IOS 12.2(33)SXI4a consisting of
2 Chassis, each with 1  Supervisor 720 10GE running  PFC3CXL.
I want to add redundant Supervisories in each Chassis without interrupting
user applications. Are redundant Supervisories hot swappable ? Are
there any special considerations which must be followed when
forming a quad sup VSS System ?
Manfred
Reza Sharifi Thu, 09/09/2010 - 12:29
  • Cisco Designated VIP,
    2017 LAN
Hi Manfred,
In a Quad Sup VSS, the primary Sup in each switch is in SSO Active mode while the stand-by sup should be in RPR Warm mode.
Even though it sounds reasonable to be able to add a second sup to each switch without interrupting user application, I would not do it without on outage window.
Also, since this is very very new technology, I would do extensive testing before putting this in production.
Reza
