CRS Eng and Administration
Sep 9th, 2010
Dear all
I star installing my CRS Server , but the CRS Eng and Administration are always down
It I restar , its came back to dows after few minutes
Can some one help with thid issues ?
Brgds
Aaron Harrison Thu, 09/09/2010 - 11:49
  • Community Spotlight Award,
    Member's Choice, May 2015
Post up your latest MIVR and MCVD logs from c:\program files\wfavvid\log if it's v7.0, or retrieve them from the server using 'file get' or RTMT if it's v8.0.
Usually this is a problem on the Windows version of the app caused by changing the IP address or hostname of the server AFTER installing the UCCX application from CD. Some config files have the old IP/hostname in.
Easiest fix is to rebuild, and use the correct IP/hostname first time and don't change it.
If you don't think you've changed those details, post up the logs and someone will take a look.
Aaron
Please rate helpful posts...
