Unsigned IOS images ??
Sep 9th, 2010
  I installed a new IOS load on my 2951 and but it failed to boot with the following error.
IOS Image Load Test
___________________
Unsigned Image Found, bailing out
Signature DID NOT VERIFY
boot: cannot load "flash0:"
  Is there something wrong with c2951-universalk9-mz.SPA.151-2.T1.bin?  Or is there additional steps with the 2951 that I haven't learned about yet.  This is my first 2900.
Greg
vragotha Thu, 09/09/2010 - 16:36
  • Silver, 250 points or more
Please post the complete boot log.
Try breaking into ROMMON and post a 'dir flash:' and 'set'
vragotha Thu, 09/09/2010 - 16:46
The IOS may also be corrupt. May want to try downloading a fresh copy off cisco.com and reloading it on the flash
Leo Laohoo Tue, 05/21/2013 - 00:06
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Have you resolved it?
Post the entire bootup process of your router.
Also post the output to the command "dir flash:"
Ivanpomidorov Wed, 05/22/2013 - 05:01
bootup process:
System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
Copyright (c) 2010 by cisco Systems, Inc.
Total memory size = 512 MB - On-board = 512 MB, DIMM0 = 0 MB
CISCO2901/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/-1(On-board/DIMM0) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
IOS Image Load Test
___________________
Signature did not verify
Compact Flash1: Not present
IOS Image Load Test
___________________
rommon 42 > dir flash0:
Directory of flash0:
2      82005760  -rw-     c2900-universalk9_npe-mz.SPA.152-2.T1.bin
Leo Laohoo Wed, 05/22/2013 - 17:16
  • Hall of Fame,
    2017 LAN, Wireless
Download the IOS again from the Cisco website.
Eject the CF from the router and use a multi-card reader to overwrite the file.
Subeh Sharma Wed, 05/22/2013 - 19:50
As you can see from the logs you pasted the image is corrupted:
Signature did not verifySignature DID NOT VERIFYboot: cannot load "flash0:"
As the post above suggest, download the image again and use this link to check for any corruption in the image:
http://www.cisco.com/web/about/security/intelligence/iosimage.html
Subeh
Lappian0815 Fri, 01/31/2014 - 00:24
I have a similar problem as GREGORY GEE!
my Router 2951 is not booting the Image:
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.3(3)M, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 22-Jul-13 04:58 by prod_rel_team
: Unexpected exception to CPU: vector 300, PC = 0x4338994 , LR = 0x4338990
-Traceback= 0x4338994z 0x4006DB4z 0x42DED9Cz 0x42DED9Cz 0x4006E70z 0x42ED9F4z 0x42F3EC8z 0x59410A8z 0x5941410z 0x4E32070z 0x4E193B8z
M8500 CPU Register Context:
PC   = 0x04338994  MSR  = 0x02029200  CR   = 0x24008042  LR    = 0x04338990
CTR  = 0x04E1EEF0  XER  = 0x00000000  DEAR = 0x042EDA00  PVR   = 0x80210030
DEC  = 0x00002E5C  TBU  = 0x00000000  TBL  = 0x1C70116B
DBCR0= 0x41000000  DBCR1= 0x00000000  DBCR2= 0x00000000
IAC1 = 0x00000000  IAC2 = 0x00000000  DAC2 = 0x00000000  DAC2  = 0x00000000
R0   = 0x8009FA00  R1   = 0x017A5BF0  R2   = 0x75FFF7BF  R3    = 0x10935A80
R4   = 0x0C56E914  R5   = 0x00000000  R6   = 0x05A2BD68  R7    = 0x00000000
R8   = 0x00000002  R9   = 0x10930000  R10  = 0x017A5B48  R11   = 0x00000000
R12  = 0x44008082  R13  = 0x9D31D183  R14  = 0x11820000  R15   = 0x00000002
R16  = 0x0000FFFF  R17  = 0x11830000  R18  = 0x100000A4  R19   = 0x11DD59A0
R20  = 0x11DD229C  R21  = 0x00000000  R22  = 0x11DD5C54  R23   = 0x1C700336
R24  = 0x1003A49C  R25  = 0x1183E5D0  R26  = 0x11820000  R27   = 0x00000004
R28  = 0x00000002  R29  = 0x042EDA00  R30  = 0x00000000  R31   = 0x042EDA00
TEXT_START : 0x040001A0
DATA_START : 0x0C000000Invalid path _20060102-000004-UTC
No fault history 0x0
=== Flushing messages () ===
Buffered messages:
Queued messages:
*Jan  2 00:00:06.923: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan  2 00:00:02.543: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
*Jan  2 00:00:02.587: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2951 Next reboot level = ipbasek9 and License = ipbasek9
*Jan  2 00:00:02.663: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2951 Next reboot level = securityk9 and License = securityk9
*Jan  2 00:00:02.735: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2951 Next reboot level = uck9 and License = uck9
*Jan  2 00:00:04.579: %MAINBOARD-4-ECC_SINGLE: A corrected single bit error has occurred in DRAM at location 0x42EDA0
*** System received a SegV exception ***
signal= 0xb, code= 0x300, context= 0x119c2108
PC = 0x4338994, Vector = 0x300, SP = 0x17a5bf0
System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Total memory size = 1024 MB - DIMM0 = 1024 MB, DIMM1 = 0 MB
CISCO2951/K9 platform with 1048576 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
program load complete, entry point: 0x4000000, size: 0x18fa0
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c2951-universalk9-mz.SPA.152-1.T.bin"
I have deleted the Image "c2951-universalk9-mz.SPA.152-1.T.bin" on the Flash
and load up the new Image "c2951-universalk9-mz.SPA.153-3.M.bin", but the Router
don´t leave the Booting Process and end in a Booting-Loop.
Please help
Andi
Related Content
