Commands to Verify Transcoder config and sessions.
wrightmp
I have configured numerous 28XX for transcoding resource on various versions of callmanger and they work fine. However I have never been able to view the live transcoding rtp sessions as they occur on the router (28XX). I know that the transcoder is doing its job - as i can browse to the IP address of the Cisco phone and see that it rtp stream terminates on the transcoding router (28XX). I would however love to know the command to view the transcding sessions that are currently being used on the router (28XX). I have tried many show commands that i can see on the router without success, Can any one help??
Over the years I have used various levels of IOS - so I am sure its not a buggy IOS.
Thanks In advance Mark
Rob Huffman
Hi Mark,
Have you tried;
show voice dsp group all
show voice dsp detailed
show dspfarm dsp active
Hope this helps!
Rob
Hi - I will try and update all.
Many Thanks Mark
Steven Holl
I prefer 'sh sccp conn' for this.
William Bell
Mark,
Wouldn't "show sccp connections" give you the data you are looking for? Or
is there something missing? I know I have used it for TRP/MTP and CFB
recently. Can't recall the last time I looked at a hardware transcoded
session.
HTH.
Bill
On 9/9/10 12:53 PM, "wrightmp"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
