ASA License
Answered Question
Sep 9th, 2010
I am setting up a secondary ASA. From what I see the license between both ASAs are different but they guy who purchase the license said it will work. From what I understand it doesn't look right. Can someone please confirm will setting up the failover work with the licenses doesn't match exact or what is the minimum match in order to have the failover work.
Pirmary
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 50
Inside Hosts                 : Unlimited
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 0
GTP/GPRS                     : Disabled
SSL VPN Peers                : 25
Total VPN Peers              : 250
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 50
Total UC Proxy Sessions      : 50
Botnet Traffic Filter        : Disabled
Secondary
Maximum VLANs               : 25
Failover                    : Active/Standby
VPN-DES                     : Enabled
GTP/GPRS                    : Disabled
VPN Peers                   : 150
Thanks for you input.
Correct Answer by Allen P Chen about 6 years 7 months ago
The Security Plus license is missing from the Primary ASA, which is why failover is not supported.  Please take a look at the "High-availability support" section in the link below, notice that failover is not supported unless it has the Security Plus license:
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Hope this helps.
Correct Answer by Panos Kampanakis about 6 years 7 months ago
Yes, you need to have a matching feature set in 8.2.
In 8.3 you can share VPN users license on the units.
I hope it makes sense.
PK
Overall Rating: 5 (2 ratings)
Allen P Chen Thu, 09/09/2010 - 11:07
  • Cisco Employee,
It looks like failover is disabled on the Primary ASA, so failover will not work:
Pirmary
Maximum VLANs                : 50
Failover                     : Disabled
VPN-DES                      : Enabled
GTP/GPRS                     : Disabled
SSL VPN Peers                : 25
Are the two ASAs running the same software version?  Which license is installed on both units?  In the output of "show version", there should be something that states "This platform has an ASA.......license".
Please advise.
joe.ho Thu, 09/09/2010 - 11:18
Good catch about the version. Sorry I didn't post the correct one. Here they are.
Primary
TOR-FW1# sh ver
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
TOR-FW1 up 142 days 1 hour
Hardware:   ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0         : address is 0024.97fa.e49c, irq 9
1: Ext: Ethernet0/1         : address is 0024.97fa.e49d, irq 9
2: Ext: Ethernet0/2         : address is 0024.97fa.e49e, irq 9
3: Ext: Ethernet0/3         : address is 0024.97fa.e49f, irq 9
4: Ext: Management0/0       : address is 0024.97fa.e4a0, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Maximum VLANs                : 50
Failover                     : Disabled
VPN-DES                      : Enabled
GTP/GPRS                     : Disabled
SSL VPN Peers                : 25
This platform has a Base license.
Secondary
ciscoasa# sh ver
ciscoasa up 9 secs
Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
0: Ext: Ethernet0/0         : address is c84c.7552.110a, irq 9
1: Ext: Ethernet0/1         : address is c84c.7552.110b, irq 9
2: Ext: Ethernet0/2         : address is c84c.7552.110c, irq 9
3: Ext: Ethernet0/3         : address is c84c.7552.110d, irq 9
4: Ext: Management0/0       : address is c84c.7552.110e, irq 11
Maximum VLANs                : 100
Failover                     : Active/Active
VPN-DES                      : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
SSL VPN Peers                : 25
This platform has an ASA 5510 Security Plus license.
Panos Kampanakis Thu, 09/09/2010 - 11:30
  • Cisco Employee,
Maximum VLANs                : 50
Failover                     : Disabled
Maximum VLANs                : 100
Indeed you have a license issue. Both units will need to have a license that supports failover in order for failover to work.
I hope it helps.
PK
joe.ho Thu, 09/09/2010 - 11:34
How about security context and max vlan, will that be an issue if not match? Will they take the lowest value after they setup for failover?
Correct Answer
Panos Kampanakis Thu, 09/09/2010 - 11:41
  • Cisco Employee,
PK
Correct Answer
Allen P Chen Thu, 09/09/2010 - 12:07
  • Cisco Employee,
Hope this helps.
joe.ho Thu, 09/09/2010 - 12:18
Thank you very much for all your help. Cheers!
Related Content
