Nexus 7000 Error Message = Definition?
Sep 9th, 2010
Could someone explain to me what these error meesages mean, and what I might do to stop them?
SR17KA# 2010 Sep  9 08:45:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check version on module 10
2010 Sep  9 08:45:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check address source multicast on module 10
2010 Sep  9 08:45:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check checksum on module 10
2010 Sep  9 08:45:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check length minimum on module 10
2010 Sep  9 08:47:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check version on module 10
2010 Sep  9 08:47:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check address source multicast on module 10
2010 Sep  9 08:47:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check checksum on module 10
2010 Sep  9 08:47:22 SR17KA %EEM_ACTION-6-INFORM: Packets dropped due to IDS check length minimum on module 10
Thanks for your assistance,
// Craig Baugh
// [email protected]
Overall Rating: 0 (1 ratings)
Tharak Abraham Fri, 09/10/2010 - 08:46
  • Bronze, 100 points or more
"sh hardware forwarding ip verify "
and you will get the list of all the IDS related commands enabled.
You have to turn it off based on your requirements
For eg:- "no hardware ip verify length minimum" can turn off this message
