Does AnyConnect support a single SSL Tunnel to reach all resources by FQDN behind an ASA5505?
Sep 9th, 2010
Hi All,
I was wondering if a full SSL Tunnel configuration is possible where you would not need to define all the apps you wanted to reach behind the ASA?
Thanks.
Jon
Federico Coto F... Thu, 09/09/2010 - 22:17
  • Green, 3000 points or more
You need to define the apps that you want to access when you use clientless SSL (webvpn portal)
If you use AnyConnect, then you have a full tunnel (pretty much like an IPsec client tunnel where you have full access to the remote network just like if you're sitting there)..
Federico.
