show ip eigrp neighbor
Answered Question
Sep 9th, 2010
Hello there!
I am not able to find out the info related to the numbers under "H" column in output of sh ip eigrp nei command. I tried cisco command references but in vain. Could some one kindly help me understand?
Thank you...
Ramchander Kunta
Correct Answer by David Salazar about 6 years 4 months ago
Hi, rkunta.
As Jon say the H value is the order as EIGRP neighboring is established.
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_s2g.html#wp1042403
Table 45     show ip eigrp neighbors Field Descriptions
Field
Description
process 77
Autonomous system number specified in the router configuration command.
H
This column lists the order in which a peering session was established  with the specified neighbor. The order is specified with sequential  numbering starting with 0.
Address
IP address of the EIGRP peer.
Interface
Interface on which the router is receiving hello packets from the peer.
Holdtime
Length of time (in seconds) that the Cisco IOS software will wait to  hear from the peer before declaring it down. If the peer is using the  default hold time, this number will be less than 15. If the peer  configures a nondefault hold time, the nondefault hold time will be  displayed.
Uptime
Elapsed time (in hours:minutes: seconds) since the local router first heard from this neighbor.
Q Count
Number of EIGRP packets (update, query, and reply) that the software is waiting to send.
Seq Num
Sequence number of the last update, query, or reply packet that was received from this neighbor.
SRTT
Smoothed round-trip time. This is the number of milliseconds required  for an EIGRP packet to be sent to this neighbor and for the local router  to receive an acknowledgment of that packet.
RTO
Retransmission timeout (in milliseconds). This is the amount of time the  software waits before resending a packet from the retransmission queue  to a neighbor.
Version
The software version that the specified peer is running.
Retrans
The number of times that a packet has been retransmitted.
Retries
The number of times an attempt was made to retransmit a packet.
Restart time
Elapsed time (in hours:minutes: seconds) since the specified neighbor has restarted.
I hope help you.
Correct Answer by Jon Marshall about 6 years 4 months ago
rkunta wrote:
Hello there!
Thank you...
Ramchander Kunta
Ramchander
The H column simply shows the order in which the EIGRP neigborships were established.
Jon
Overall Rating: 5 (4 ratings)
Correct Answer
Jon Marshall Thu, 09/09/2010 - 15:01
rkunta wrote:
Hello there!
Thank you...
Ramchander Kunta
Ramchander
Jon
rkunta Thu, 09/09/2010 - 20:26
Jon,
Appreciate your help - thank you very much. That helps me...
Warm Regards,
Ram
Correct Answer
David Salazar Thu, 09/09/2010 - 15:11
Hi, rkunta.
Field
Description
process 77
H
Address
Interface
Holdtime
Uptime
Q Count
Seq Num
SRTT
RTO
Version
Retrans
Retries
Restart time
I hope help you.
rkunta Thu, 09/09/2010 - 20:28
Thank you for the Link David, Somehow I seem to have missed it in my search...thank you...
Warm Regards,
Ram
Peter Paluch Fri, 09/10/2010 - 12:09
Hello Ram,
In addition to great Jon's and David's posts, the H letter in the first column supposedly stands for "Handle" - a number internally representing a particular EIGRP neighbor. The neighbors are numbered in sequential increasing order as they are detected.
Best regards,
Peter
Related Content
