09-09-2010 02:37 PM - edited 03-19-2019 01:33 AM
I have a customer who have (2) Nortel Meridian 81 and (1) CS1000 for their 3 locations along with Octal 350 servicing 2500 voicemail users today. Customer also has a Cisco UCM in their network today which is servicing their wireless phone users.
UCM and CS1000 are networked together using Q.Sig trunks today. Customer is looking at replacing their Octal solution with a new Voice mail solution.
I was looking at integration documents for Unity Connection using PIMG.
In this scenario, would I need 3 separate PIMG 's at the three remote sites and integrate it with Unity connection or Can I achieve this using just one PIMG at one of the sites, considering the three sites are trunked together using tie-trunks.
Appreciate any pointers/ help.
09-09-2010 10:27 PM
In a digital integration, you "should" be able to accomplish this via a PIMG or a stack of PIMGs (i.e., you'll want more than 8 ports most likely). If you were forced to do a serial integration, you would need one PIMG (or stack) per PBX integration.
Hailey
Please rate helpful posts!
09-13-2010 03:49 PM
thanks
09-10-2010 06:27 AM
Hi there,
Just to add a note to the great tips from Hailey (+5 Hailey!)
We are in the final stages of replacing our "old" Octel with Unity Connection, part of
which is integrated to our CS1000 and CUCM in a "Hybrid" deployment like yours
Centralized Voice Messaging
Cisco Unity Connection supports centralized voice messaging through the phone system, which supports
various inter-phone system networking protocols including proprietary protocols such as Avaya DCS,
Nortel MCDN, or Siemens CorNet, and standards-based protocols such as QSIG or DPNSS. Note that
centralized voice messaging is a function of the phone system and its inter-phone system networking,
not voice mail. Connection will support centralized voice messaging as long as the phone system and its
inter-phone system networking are properly configured.
Setting Up a Nortel Meridian 1 Digital PIMG
Integration with Cisco Unity Connection
09-13-2010 03:47 PM
Thank you
