CLI based Roles/Views
Sep 9th, 2010
Hi Guys,
I'm trying to configure a view that will allow a user access to do a few mundane tasks such as read the startup conifg, a few show commands, change the terminal settings, etc.
I've configure a view called RO and assigned a few exec commands (see below):
parser view RO
secret 5 $1$m3Iz$ltDKR58NxImIZEEwX/vbV0
commands exec include terminal length
commands exec include show startup-config
I've also created a user and assigned it to this view
username sc view RO password 0 sc
Now, when I login with the user sc I am unable to move from user mode to privliged mode, I get an access denied error as seen below:
R1>en
Password:
% Access denied
Have I done something wrong? How do I configure the router so that I can create a role with the required commands and assign it to users? I thought I had it down pat but it isnt working.
Any advice you have would be greatly appreciated
TIA
Rgds
Scott
Overall Rating: 3.5 (2 ratings)
Panos Kampanakis Fri, 09/10/2010 - 07:40
Scott,
Your user probably does have priv level to be in enable mode.
IF he is in priv 15, does it work?
PK
Scott Cannon Mon, 09/13/2010 - 15:34
Hi PK,
Thanks for your input.
If I give the account privilege 15 it works but then the view does not (ie. the account can run all commands). I suspect this is how it should be since priv15 is akin to god-mode access and you shouldnt be able to restrict it. Also means, giving privilege 15 isnt a solution. I've scoured the web with no luck.
Can any one offer further insight into my issue?
TIA
Rgds
Scott
Scott Cannon Sun, 09/19/2010 - 22:20
Hi Guys,
This issue persists. Is anyone able to offer some insight/suggestion on my problem?
TIA
Rgds
Scott
wzhang Fri, 10/08/2010 - 09:45
The "Access denied" error comes from aaa authentication, and in theory shouldn't have much to do with role based view access. Does this work if you don't assign the RO view to this user "sc"? Also, if you assign both a parser view and the privilege level to an user, the parser view should take precedence, ie., the users should still only be able to see commands assigned to the view, and not all commands under level 15. To better understand what's going on, could you post your aaa configuration, along with a "debug aaa authen" when it's not working?
Wen
Scott Cannon Mon, 10/18/2010 - 21:44
Hi wzhang,
Thanks for coming back to me on this. The fix for this problem still eludes me.
If I dont assign the RO view to the user and enable it fails authentication (wrong passowrd) If I then manually tell the user to enable (into) the RO view then it works.
If I assign priviledge level 15 to the line the user is automatically logged into exec mode and has access to all commands, regardless of what view is assigned to the user.
I think whats happening is this:
When the view is assigned to the user SC, I login as SC and type enable at the user prompt. Instead of enabling the view assigned to the user (in this case RO) it enables the root view and as such fails authentication. If I manually enable the RO view via enable view RO it works as expected.
I suppose my question now is: How do I change this behaviour so that when a user with a view assigned o them types enable, it moves them into the view assigned to them (and not the root view)?
TIA
Rgds
Scott
wzhang Tue, 10/19/2010 - 07:06
Hi, Scott:
Could you share your aaa configuration? A couple of things to note here:
1. With aaa authorization enabled, when an user logs into the router he should automatically be assigned the view that the user belongs to. You shouldn't have to enable into the view manually.
2. When the user is in the view he/she's assigned to and he/she types "enable", then he will be put into the privileged mode, and not the root view as in the following:
R1#telnet 1.1.1.1
Trying 1.1.1.1 ... Open
User Access Verification
Username: cisco
Password:
R2#sh parser view
Current view is 'MYVIEW'
R2#
R2#enable
Password:
R2#
R2#sh parser view
No view is active ! Currently in Privilege Level Context
R2#
3. You typically don't want to assign privilege levels to the line, but instead you want to do it for the user either through AAA or assign it locally, although with role based CLI access, it's somewhat of a moot point since the commands the user has access to is controlled by the view and not the privilege level.
Wen
Scott Cannon Tue, 10/19/2010 - 21:14
Hi Wen,
See config extract below:
VIEWS_R1#sho run
Building configuration...
Current configuration : 1218 bytes
version 12.4
hostname VIEWS_R1
boot-start-marker
boot-end-marker
enable password password
aaa new-model
aaa authentication login default local
aaa authorization exec default if-authenticated
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username sc privilege 15 password 0 abc123
username sc2 view RO password 0 abc123
interface FastEthernet0/0
ip address 10.0.0.1 255.0.0.0
duplex auto
speed auto
line con 0
logging synchronous
line aux 0
line vty 0 4
transport input telnet
line vty 5 14
line vty 15
parser view RO
secret 5 $1$E6ex$JrkjcJd94q4vM/QrQL9F31
end
Note: This config differs slightly from that mentioned in my previous posts. I've had to rebuild it as I lost my test environment. In the above config, the user sc2 is assigned the view RO. I'm doing all this testing in GNS3, happy to upload the configs for you if you prefer.
A difference I have noticed between your output and what I get is that my user "sc2" is not logged into privilged mode. I guess this is because I dont have it set on the vty lines. If I do set it, as already stated, the view doesnt take affect and the user gets all commands available to that priv level.
Heres what I see (I've added the passwords so you can see waht I'm doing):
Username: sc2 (this user has the RO view assigned to them)
Password: abc123
VIEWS_R1>en
Password: RO (the RO view enable password)
% Access denied
VIEWS_R1>en
Password: password (the root view enable password)
VIEWS_R1#sho parser view
VIEWS_R1#sho run | i sc2
VIEWS_R1#
Any idea why my view isnt taking affect?
Rgds
Scott
wzhang Wed, 10/20/2010 - 06:34
Hi, Scott:
I think the problem is that your aaa authorization is not taking effect, thus not putting the user into the parser view assigned to him. With your authorization configuration, if-authenticated means don't authorize if the user is authenticated already. Try changing that to "aaa authorization exec default local" and that _should_ fix it. The reason that my user goes into the privileged mode right away is because I've assigned privilege 15 to the user. But then again, with role based cli access, the parser view should take precedence over the privilege level, so it's somewhat of a moot point. Hope this helps.
Wen
Rowell Dionicio Thu, 10/11/2012 - 05:55
I know this is an old post but I came across the same issue. The way I resolved it is to not have the user do an enable after inputting their credentials. At user mode they need to type:
R1> enable view RO
Password: RO-password
R1#
*Oct 11 05:54:26.523: %PARSER-6-VIEW_SWITCH: successfully set to view 'RO'.
