Option 43 for Cisco 1524
Answered Question
Sep 9th, 2010
What is the Type value for LAP 1520 ?
When DHCP servers are programmed to offer WLAN Controller IP addresses as Option 43 for Cisco Aironet LAPs, for example, Cisco Aironet 1130, 1140, 1200, 1230 and/or 1240 series access points, the sub-option TLV block is defined in this way:
    * Type—0xf1 (decimal 241)
    *  Length—Number of controller IP addresses * 4
    *  Value—List of the WLC management interfaces, typically translated to hexadecimal values
The Type value is : *  Type—0xf1 (decimal 241) ? for access points 1520 ?
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml#p2
Correct Answer by rob.huffman about 6 years 4 months ago
Hi Ricardo,
The format of the TLV block for 1100, 1130, 1200, 1240, 1250, 1300, and 1520 series access points is listed below:
•Type: 0xf1 (decimal 241)
•Length: Number of controller IP addresses * 4
•Value: List of WLC management interfaces
From this good doc;
Cisco Aironet 1520 Series Outdoor Mesh Access Point Hardware Installation Guide
http://www.cisco.com/en/US/docs/wireless/access_point/1520/installation/guide/1520_axf.html#wp1007791
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Fri, 09/10/2010 - 05:42
Hi Ricardo,
From this good doc;
Cheers!
Rob
