How do I force PfR to route VoIP traffic over a specific interface?
danieltien
I'm hoping someone can give me some guidance with respect to PfR.  In our production environment, we have a 2851 ISR running CME 8.1 with frame relay over T1 for our VoIP/SIP service with Verizon.  We are also able to use non VoIP bandwidth for internet traffic.  We also have a DSL line that we currently use for our primary internet access.
My understanding is that we can use PfR to bring both interfaces into the router and have a sort of load-balancing/failover system in place.  That said, we need to keep VoIP services on the T1.  Is it possible to set a static path to a specific exit for VoIP traffic and allow PfR to balance the rest?
Steve Lyons
Daniel,
The specific feature of PfR you are asking about is called link-groups. If you are familiar with QoS class-maps and policy-maps PfR has the same capability to classify traffic and then make decisions of what to do with these traffic classifications. In PfR this is called traffic-classes and pfr-maps where traffic-classes are similar to class-maps and oer-maps are similar to policy-maps.
The first step you will need to accomplish is to define which link-groups your external interfaces are associated. Then you create the traffic-class and oer-maps. When you are creating your oer-maps per application you will define the primary link-groups and backup link-groups.
Please refer to our documentation regarding link-groups
http://www.cisco.com/en/US/docs/ios/pfr/configuration/guide/pfr-link-group_ps10592_TSD_Products_Configuration_Guide_Chapter.html
Also note in older codes pfr-maps are called oer-maps.
Let me know if you have further questions.
Best Regards,
Steve Lyons - Cisco
Daniel,
To know details about VOIP join the forum http://www.voipbiznessforum.com/
Thnx
