SPA525G appears no MWI & missed call Notification
Answered Question
Sep 10th, 2010
I am a Sipgate.de customer. On my SPA525G appears no MWI? Are there settings to receive the MWI signal? Perhaps the "Call Feature Settings"? The phone calls over SIP works without problems.
By the Way: Is there a missed call Notification which will flash etc. or just the missed call Shortcut?
Thanks a lot,
Sascha
Correct Answer by Alberto Montilla about 6 years 7 months ago
Hi Sascha;
Glad to hear that MWI works properly.
For the second, there is a big LED on top of the screen that is highlighted when MWI is present. Please let me know if it is not your case.
Please, I would appreciate if you mark this question as answered. This will help others to find this question/answer easily.
Alberto
Overall Rating: 5 (2 ratings)
Alberto Montilla Fri, 09/10/2010 - 10:36
  • Cisco Employee,
Dear Sir;
MWI works in conjunction with your service provider. Please check with sipgate whether they implement MWI according to SIP standards. With regards of the miss call notification, basically the indication is on the screen notification, shortcut, as well as call history (there is a missed call menu).
Alberto
baseXolutions Fri, 09/10/2010 - 13:51
Hi Alberto,
Sipgate sends the MWI, they say. I have forgotten the MailboxID. The problem is solved.
The configuration instructions from Sipgate.de missing two important details:
Correct settings:
Okay, so there is no way to get a flashing LED ?
Thanks a lot.
greetz, Sascha
Correct Answer
Alberto Montilla Tue, 09/14/2010 - 08:18
  • Cisco Employee,
Hi Sascha;
Alberto
Related Content
