What is the Max speed Stacking ?
Answered Question
Sep 10th, 2010
Hi All
What is the maximum speed of  trunk/stack can be configured in WS-C3750G-24T-Switch?
Siva
Correct Answer by francisco_1 about 6 years 10 months ago
No. As already mentioned above to have 10g interface, you gonna have to upgrade to 3750-E or 3750 or 3560 X series. They support 10GbE SFP+ Ports.
On 3750g, you proberbly can have max 8g by aggregating 8 ports in a port-channel.
Francisco.
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Fri, 09/10/2010 - 07:00
  • Cisco Employee,
The maximum speed supported by each Stack cable is 16 Gbps. Since you will
have two paths in the stack, the effective speed will be 32 Gbps. Trunking
speed depends upon the type of link you are using. If you are using Gig
Links, it will be a max of 1 Gig (if you go for Etherchannel with multiple
Gig links, then it will be sum of the total bandwidth of all gig links).
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_w...
_paper09186a00801b096a.html
Hope this helps.
NT
madathilsiva Fri, 09/10/2010 - 07:27
Thanks NT
Can u please tell me what is the maximum trunk speed an configure in this switch?
will it support 10 Gb trunk?
francisco_1 Fri, 09/10/2010 - 08:49
  • Gold, 750 points or more
The 3750-E versions have the 10GB ports. http://www.cisco.com/en/US/products/ps7077/
Regarding the stacking speed just to add to above comments, when two or more switches are connected via stackwise cable, a switch fabric consisting of dual counter-rotating rings if formed, with each ring providing 16Gbps of bandwidth, resulting in 32Gbps of total bandwidth.
Francisco.
francisco_1 Fri, 09/10/2010 - 09:01
Just to add to that the StackWise Plus and StackWise can support up to 2 Ten Gigabit Ethernet ports per Cisco Catalyst 3750-E
Francisco.
Nagaraja Thanthry Fri, 09/10/2010 - 08:58
  • Cisco Employee,
3750E and 3750X switches support 10G links. Regular 3750 does not support
10G modules. So, if you have 10G module, then yes, you can have a trunk of
10G bandwidth.
NT
madathilsiva Sat, 09/11/2010 - 03:08
so you mean to say i can add 10g module
in this switch(3750g)
Thank you very much.
Correct Answer
francisco_1 Sat, 09/11/2010 - 05:01
Francisco.
