VPN and AD
Sep 10th, 2010
Has anyone setup anyconnect with AD Network. We want to setup a way to login to AD to get map drives and get in thru the anyconnect client. I read you had to do a xml profile. Not sure on this can anyone help with this. Thanks
Antonio Knox Fri, 09/10/2010 - 08:09
  • Silver, 250 points or more
Assuming your VPN configuration allows full IP tunneling, and you have the domain name, DNS server(s) and WINS servers set up in your group policy, you should be able to successfully use all of your AD-related services upon connecting to VPN.  I'm not sure if this answers your question, but if not, could you expand on your question?
Please rate the post if it helps.
ARMANDO ALVARADO Fri, 09/10/2010 - 08:31
Would this something like Start before logon or is this a totally different thing. What about PLAP for win7. This is probably what we are trying to do hope this helps.
