09-10-2010 07:46 AM - edited 03-16-2019 12:42 AM
We have a central site that has its first remote site office. The call handler in the remote office offers the directory handler as an option to callers. When a caller to the remote site is in the directory handler and presses the zero key the caller is reaching the receptionist in the central site and we are being asked to stop this from happening.
Is there a way to create a separate directory handler that will work completely separate from the parent directory handler so that the receptionist in the central site doesn't get these calls?
Please let me know if you do.
Thank you.
Rgds,
Vicky
Solved! Go to Solution.
09-10-2010 08:57 AM
Hey Vicky,
This is most possible my friend
The new Directory Handler search>scope can be based on these criteria (the one
I just created is based on the peeps in my group @ work in a PDL);
Entire Server
COS
PDL
Search Space
Once you have created your new Directory Handler you can edit the Caller Input
"if caller presses zero" setting (The test one I set up is set to go to a Call handler which
has no Greeting and transfers to the Operator @ 7001). This is where
you can determine where the Dial 0 goes to.
Cheers!
Rob
09-10-2010 08:57 AM
Hey Vicky,
Entire Server
COS
PDL
Search Space
Cheers!
Rob
09-10-2010 10:46 AM
Hi Rob,
Thank you for the reply. I am checking this out now. Going to do some testing.
Thank you again.
