mirober2 Fri, 09/10/2010 - 09:02
  • Cisco Employee,
It sounds like you don't have standby IP addresses configured for the interfaces. You can do this with the following command under the interface config:
ip address standby
When you configure those, you should see them listed in the 'show ip address' output.
Hope that helps.
-Mike
m.ancheta Fri, 09/10/2010 - 09:17
I have all my ip address showing in the primary
System IP Addresses
           ip address eobc 127.0.0.81 255.255.255.0
        ip address inside 10.254.15.4 255.255.255.248
        ip address WiFi-Proxydmz 10.254.50.5 255.255.255.0
        ip address enterprisedmz 10.254.15.17 255.255.255.248
        ip address fimsdmz 10.254.36.1 255.255.255.0
        ip address failoverdmz 10.254.15.9 255.255.255.248
but if i am on the secondary, i only see:
System IP Addresses:
Current IP Addresses:
        ip address failoverdmz 10.254.15.10 255.255.255.248
All my failover commands for secondary unit are in there.
mirober2 Fri, 09/10/2010 - 09:49
  • Cisco Employee,
Hi Manny,
Looks like we have a TAC case open for this together as well : ) Let's troubleshoot under the TAC case and we can post the answer for the rest of the folks once we get it solved.
-Mike
Related Content
