Trouble Calling Italy from the UK
I have an issue calling to Italy from the UK.  I have a router with PRI and can place calls to the US and other countries.  When i call Italy, i get a message that states: "the # u have dialed is not recognised"
When I call the same number from a PRI in the US, the call goes through just fine.  I have pasted the debugs for the bad call and the good one.  Any help would be appreciated.
GOOD CALL PLACED FROM US PRI TO ITALY
*Sep 10 12:24:52.169: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0868
Sending Complete
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98396
Exclusive, Channel 22
Facility i = 0x9FAA06800100820100A117020100020100800F4D616C636F6C6D2054797272656C6C
Calling Party Number i = 0x0081, '1753603034'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '9011390773615209'
Plan:ISDN, Type:National
*Sep 10 12:24:52.217: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8868
*Sep 10 12:24:54.389: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x8868
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Sep 10 12:24:54.933: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0868
Cause i = 0x8090 - Normal call clearing
*Sep 10 12:24:54.961: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8868
*Sep 10 12:24:54.977: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0868
CALL FAILS PLACED FROM UK-LANGLEY PRI TO ITALY
get message "the # u have dialed is not recognised"
Sep 10 17:06:37 CEST: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x005D
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0xA9838E
Exclusive, Channel 14
Called Party Number i = 0xA1, '00390773615209'
Sep 10 17:06:38 CEST: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x805D
Sep 10 17:06:38 CEST: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x805D
Progress Ind i = 0x8482 - Destination address is non-ISDN
GBLAVG01(config-if)#do sh voice call summary | inc 0/0/0
0/0/0:15.1 - - -
0/0/0:15.2 - - -
0/0/0:15.3 - - -
0/0/0:15.4 - - -
0/0/0:15.5 - - -
0/0/0:15.6 - - -
0/0/0:15.7 - - -
0/0/0:15.8 - - -
0/0/0:15.9 - - -
0/0/0:15.10 - - -
0/0/0:15.11 - - -
0/0/0:15.12 - - -
0/0/0:15.13 - - -
0/0/0:15.14 - - -
0/0/0:15.15 g729br8 n S_CONNECT
Related Content
