Problems with 'N' on autonomous AP 1142
Sep 10th, 2010
Hello!
I have 2 autonomous AP 1142.
And i try to make 802.11n connection between them using 2.4GHz interfaces,
setting of ssid of both AP's are the same, WPA2/AES, WMM enabled by default.
Using GUI i can see throughput from 1 to 54 Mbit/s, but it is less then max speed of 802.11n.
Do you know how to solve this problem?
Maxim_Sharoglazov Sat, 09/11/2010 - 01:04
Yes, i enabled rates from 1 to 15 Mbit/s.
I'm new in 1142, can i connect 2 autonoumous 1142 AP's using 'N' to test connection between them?
corsair1969 Sun, 09/12/2010 - 23:34
Check on the 802.11a/n settings 11n mode is enabled and that you have the "High Throughput (802.11n) MCS Data Rates enabled 7Mbps thru 144Mbps.
You will not see the higher datarates in the 802.11a/n Network , this only shows Data Rates 6Mbps thru 54Mbps.
Hope this helps
David
