Another problem with autonomous AP 1142
Our customer has 4 autonomous AP 1442 but he can't connect them using 802.11n throughput at 2.4GHz radio interface.
The best throughput he has is 54Mbit/s. Using GUI and CLI he can see only throughput from 1 to 54Mbit/s.
System software version: 12.4(21a)JA1
Bootloader version: 12.4(18a)JA3
How to solve this problem?
Stephen Rodriguez
To be able to get N rates, you must either be completely open, or be using WPA2/AES.  You must also have WMM enabled,
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
corsair1969
Check on the 802.11a/n settings 11n mode is enabled and that you have the "High Throughput (802.11n) MCS Data Rates enabled 7Mbps thru 144Mbps.
You will not see the higher datarates in the 802.11a/n Network , this only shows Data Rates 6Mbps thru 54Mbps.
Hope this helps
mikewilder
Can anyone provide a working config for WPA2/AES on an autonomous 1142?  I can get high N rates when network is open but cannot with what I think is appropriate config for AES and WPA2.  The AP is running 12.4(25d)JA.  Here is config:
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
no aaa new-model
dot11 syslog
dot11 vlan-name Default vlan 1
dot11 ssid Test
   vlan 101
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 05080F1B334556470C1645
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 101 mode ciphers aes-ccm
ssid Test
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.101
encapsulation dot1Q 101
no ip route-cache
bridge-group 101
bridge-group 101 subscriber-loop-control
bridge-group 101 block-unknown-source
no bridge-group 101 source-learning
no bridge-group 101 unicast-flooding
bridge-group 101 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 101 mode ciphers aes-ccm tkip
ssid Test
antenna gain 0
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.101
no ip route-cache
bridge-group 101
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.101
no ip route-cache
bridge-group 101
interface BVI1
ip address 10.1.0.31 255.255.255.0
no ip route-cache
ip default-gateway 10.1.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community XXXXXX RO
bridge 1 route ip
line con 0
line vty 0 4
login local
end
no ip address
no ip route-cache
ssid Test
antenna gain 0
dfs band 3 block
channel dfs
station-role root
Use only one encryption at a time..For 802.11n rates, aes-ccm needs to be configured. Please remove tkip.
It should be:
no ip address
no ip route-cache
ssid Test
antenna gain 0
dfs band 3 block
channel dfs
station-role root
