On a 1841 - Backup interface for vlan inerface - tunnel interface
Sep 10th, 2010
Hi:
On a Cisco 1841 router I  have an Interface vlan configured. Also I have  f0/0/1 interface  defined as switchport access with the same vlan. Is it possible to now define a tunnel interface and have it include the following  - backup interface vlan xx ?
Interface vlan 55
     ip addresss 10.0.0.1 /24
interface f0/0/1
     ip address  10.0.1.100 /24
     switchport access vlan 55
interface tunnel5
     backup interface vlan55
     ip address 10.0.2.33/24
Is this configuration valid on a 1841 with these interfaces ? Can the "backup interface " be used in this situation ?
Thanks for any help.
David Salazar Fri, 09/10/2010 - 10:33
Hi, mikir
I see a mistake in the configuration.
a) interface f0/0/1 (A interface can not be layer 3 (ip add 10.0.1.100/24) and the same time be a Layer2 (Switchport access vlan 55))
**** To have a Interface fastethernet as layer2 interface you need issue the command "no switchport".
In other order of idea, you can use a Interface VLAN (SVI) as Backup interface, but if you have more than one port in the Vlan 55 any physical port member of the vlan can be use.
I hope help you
mikik Fri, 09/10/2010 - 13:58
Hi David:
Thanks for the answer. You are correct , the interface f0/0/1 is switchport access and no ip address. I simply did not write it correctly in the question.
I  did not see in Cisco  examples the use of 'backup interface" in this kind of situations. Mostly just for dialer interface. So i understand that this should work. There is in fact  only one interface in the vlan.
Mickey
