Can't call Analog Sets
Sep 10th, 2010
All,
     I have configured the UC540 FXS with 2 user and 2 fax type extensions.
All the FXS ports can call the IP Sets.
However whenever an IP Set or Analog set tries to call an Analog set I just get a busy tone.
Nothing can call my analog sets.
I'm guessing I'm missing something in the config.
I'd appreciate any pointers.
Chris
Steven DiStefano Fri, 09/10/2010 - 11:33
Hi Chris,
Did you use TSW (Telephpony Setup Wizard) to configure FXS analog stations?
Did you configure them as User Mode?
What extensions did you assign them?
Steve
chris parkinson Fri, 09/10/2010 - 14:12
Here's the current config:
Port          Role      Sig     Ext
0/0/0          User     LS     221
0/0/1          FAX     LS     222
0/0/2          User     LS     223
0/0/3          User     LS     224
Chris
Steven DiStefano Fri, 09/10/2010 - 18:50
Ok, now check to see that there is one, and only one ephone-dn for each user mode analog phone.
If you have more that one, we need to remove one.
