SA 520 Remote Management/SSL VPN
I got my SA 520 to work with IPSEC VPN but I can't get the remote management to work from the outside. Also, the SSL VPN won't work. Can I use them at the same time as the IPSEC? When I use the address in the VPN section it works on the internal network but not from external networks. How do I get it to work from external networks?
weilia Mon, 09/20/2010 - 09:38
Hi Brett,
IPsec and SSLVPN can work at the same time. Could you PM me your
configuration ?
