ā09-10-2010 10:57 AM - edited ā03-16-2019 12:43 AM
I have a problem with voice quality, the problem began 3 days ago.
if user of CME calls to PSTN , PSTN party listen CME's user voice choppy
I have already checked CME , the only thing that keep my attention was the info
displayed by the following command
#sh memory processor allocating-process totals
kmm-ccme-core# sh memory processor allocating-process totals
addto_mempool_pc_array(): overflow ----------->>>> ??????
Allocator PC Summary for: Processor
OVERFLOW = TRUE -------------->>>>>> ??????
PC Total Count Name
0x60592B74 19640512 20716 *Packet Header*
0x60EA36B4 11855492 149 Virtual Exec
0x6002F5AC 4270288 127 VTSP EVENT poo
0x604CA5EC 3976276 1 Init
0x6156B244 3187956 339 CCSIP-REGISTER
0x60CDD7C8 2868328 314 Process Stack
0x62C0ECC4 2314856 121 Init
0x604CA234 2158592 1024 Init
0x603F9400 1842400 200 Init
I just paste some part of the info.
This could be the reason of the problem??
Should I check other comands?_
Solved! Go to Solution.
ā09-10-2010 12:39 PM
I would look to see the state of the processor and memory on box:
show process cpu history
show process mem history
See if either one is reaching 100%
Is there a local PRI connected for inbound and outbound calls, or they using FXO? See if there are any physical layer problems.
And for an active call do: show call active voice brief -- Look at the delay and if you are losing any packets. Here is an example:
FFA : 846 138322120ms.1 +16650 pid:1000 Answer XXXXXXX active
dur 00:00:10 tx:496/9920 rx:495/9900
IP 10.47.16.147:16944 SRTP: off rtt:0ms pl:9180/0ms lost:0/0/0 delay:60/60/70ms g729r8 TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
ā09-10-2010 02:15 PM
ā09-10-2010 02:29 PM
No problem:
Yes there is nothing to be concered about as far as cpu. But looking at the output of show call active brief, there is alot of noise.
You can adjust the input and output but I suspect a bigger problem with the circuit. I would contact the carrier and have them test,
but unless you are seeing physical later issues on the port they probably will not see any errors either. At the lease you could
replace the cable to the niu.
1501 : 2542706 2980172720ms.1 +-1 pid:20069 Answer 7381 connected
dur 00:00:00 tx:1206/207432 rx:1383/221280
Tele 50/0/66 (2542706) [50/0/66.0] tx:24120/24120/0ms g711ulaw noise:0 acom:0 i/0:0/0 dBm
1501 : 2542707 2980174450ms.1 +-1 pid:94 Originate 949117753 connecting
dur 00:00:00 tx:1383/232344 rx:1391/222560
Tele 0/0/0:0 (2542707) [0/0/0.9] tx:27830/27830/0ms g711ulaw noise:-84 acom:6 i/0:-79/-79 dBm
ā09-10-2010 02:48 PM
Hi jaschulz,
Carrier has already checked E1; carrier's staff said that all was right....
I'm going to carry out more tests to check if there is something wrong with cables
Thanks a lot for your time
regards
