Aironet 3500: Spectrum Expert Connect Mode
Answered Question
Sep 10th, 2010
How do I connect to a 3500 to see the spectrum analysis? The manual says to download version 4.0 of the Cisco Spectrum Expert software but the latest verion is 3.3.52. What am I missing?
I want to get the most out of these new APs !!
Andrew
Correct Answer by tdennehy about 6 years 7 months ago
It is still Beta code.  Not only do you need the Beta code, but a key
as well.  After you have that installed, you log into your controller and
change the mode of your AP to SE-Connect and reboot the AP.
Then you go to the AP, copy another "key" from the AP and also
gather the IP address if it is DHCP.
You paste the key into your Spectrum Expert that is running on your
laptop, along with the IP address of the AP.
Then you can remotely see your spectrum.
I have done this before since I tested a 3500 for a few weeks before
sending it back to Cisco.
I'm impressed.. it is definately a nice feature.
Overall Rating: 5 (1 ratings)
patoberli Tue, 10/05/2010 - 07:47
  • Bronze, 100 points or more
Hi Andrew
Have you already found something? I also search for version 4.
Correct Answer
tdennehy Tue, 10/05/2010 - 11:48
andypenning Thu, 10/07/2010 - 11:08
Thanks dennehy.
We'll just have to wait until they release it!
