EIM 4.3 - Integrated Supervisor Picking Emails from Queue
Sep 10th, 2010
Well, as our list of issues grow's with integrated EIM, we just found out an integrated supervisor cannot 'pick' emails from the queue (as they could with email manager).
Has anyone found some kind of work around for this?
I have written so many work-arounds for existing problems I am almost scared that when they fix them, I'll have to just start over and rebuild my system
Barry
matthewpage Mon, 09/13/2010 - 20:29
  • Bronze, 100 points or more
Hi Barry
If you give the supervisor the administrator role as well as supervisor role I am pretty sure it will allow you to pick from the integrated queues. Also very useful as it gives the supervisor the ability to pick emails from the exception queue.
But obviously you have the down side of the supervisor having admin rights to EIM
Matt
BarryMclellan72678_2 Tue, 09/14/2010 - 06:36
Thanks Matthew!
I think it is a bug, I opened a ticket with TAC and they said that eGain did this as a 'feature' so that a supervisor could not pick from an integrated queue.
However, if you search for emails you can 'pick' emails out of the integrated queue.... so I patiently wait for an update
The whole administrator thing is kind of crapy, I would like my integrated supervisor to be able to pull some agent reports, but now, I have to give a user partition admin access to do this!
I think I am starting to face the realization that the whole integrated thing is too new with too many bugs, and I'll have to go back to standalone where everything works as documented.
Barry
lohjintiam Tue, 09/14/2010 - 11:29
Hi Barry,
If you could share other operational issues that you faced in this integrated setup, that would be great.
Thanks!
-JT-
BarryMclellan72678_2 Tue, 09/14/2010 - 19:01
yes I have posted quite a few of them here, to date, I have opened over 20 TAC cases in the last 3 months, and have only had one come back to me as a 'user' error. I don't want to turn this into an EIM bashing session as this is a new product, and I do think it will get better, I am just strugging to find ways to actually make it work at the barest level in our environment.
So far, if it wasn't for our WFM tool integrated into IPCC, we would simply have given up and gone stand alone.
lohjintiam Wed, 09/15/2010 - 04:53
"However, if you search for emails you can 'pick' emails out of the integrated queue"
This is possible without adding the admin/partition rights to the supervisor?
Thanks!
-JT-
BarryMclellan72678_2 Wed, 09/15/2010 - 10:59
Actually, I hadn't even tried this with just a supervisor ID. I have so many other issues with a plain old supervisor id, that I have been giving the supervisor user I setup admin access!
Barry
BarryMclellan72678_2 Thu, 09/16/2010 - 12:10
Well, finally talked to TAC and eGain at the same time on the phone! They told me in integrated, you should never be able to pick an email from a queue, and the work around I found was actually a bug, and they would close the loop on this for version 4.3.3
So as it stands, any integrated queues will not be able to be 'picked' from unfortunately. It's too bad that the old Email Manager can do this, but EIM cannot.
Have  a great day!
Barry
matthewpage Thu, 09/16/2010 - 12:23
That sucks pretty hard. I guess the only way your going to be able to transfer to an agent is by creating a skill group for each individual agent.:-(. Also your find that egain/cisco are quick just to say its a bug and remove the functionality rather than just fix it and make it work!!
No. Just create a script selector/dialed number for each agent. Map each to an EIM queue. All the script selectors are mapped to the one call type and this runs a script. You then use a queue to agent node. If you construct the script selector in the correct way, with the agent's peripheral number appended, you can pull that off and route the call to the agent through a single queue to agent node in implicit mode. That's how I do it and it works just fine. I increase the priority.
Geoff
matthewpage Thu, 09/16/2010 - 14:59
Great thanks ill give that a go. But let me ask you this. What happens if an agent has a load of activites assigned to them and goes on holiday how do you take those activities from that agent and assign them to some one else? I would have though you would use the pick functionality to take them off the agent? I believe there is another setting to push them back into the queue but i am assuming that is only going to work for non integrated EIM?
Matt
lohjintiam Thu, 09/16/2010 - 22:16
Would that mean I would need to have at least 1 standalone / nIPTA user to do cleanup?
Thanks!
-JT-
There is no "clean up". The emails that are pushed back are run through the same integrated queue.
I would say no to that. As I posted in another EIM thread, the non-IPTA stuff doesn't appeal to me.
Geoff
