Error: DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Binding service port failed.
Sep 10th, 2010
I am getting bellow error messages with new wlan i created. On the same WLC i have three other wlans working OK. This wlan suppose to get authenticated with acs, i tried to disable the authentication but got same error message. With acs authentication, i am able to authenticate OK but cannot get ip address from dhcp server. DHCP server is on wlc, used by other three wlans ok. All wlans are on differnt subnets; vlans created where needed.Any ideas would be appreciated.
Error from wlc:
*Sep 10 13:23:53.303: %DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Binding service port failed.
*Sep 10 13:15:33.111: %DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Binding service port failed.
*Sep 10 13:07:12.920: %DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Binding service port failed.
*Sep 10 12:58:52.732: %DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Binding service port failed.
*Sep 10 12:50:32.535: %DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Binding service port failed.
Overall Rating: 5 (4 ratings)
Surendra BG Mon, 09/13/2010 - 22:54
  • Cisco Employee,
Whats the WLC model number and the software running?? it will great if you could delete that WLAN and reconfigure the same again and also the internal pool again.
Surendra.
endpoint Mon, 09/13/2010 - 23:03
Hi, all other WLANs are working fine and dhcp pool is doing its job OK.
Actually it was config issue: i have two WLCs, one of these two is configured as anchor WLC and it was matter if setting up WLAN to have anchor WLC configured. Once i did it, everything worked perfectly.
Thanks for your response.
Aaron Miles Tue, 03/31/2015 - 16:04
I know this is an old case but I just wanted to add to it in that I just had Cisco scratching there heads for 2 weeks about an issue where we had an AP (nothing special, same as our other 100 AP's) would not allow clients to connect to it.
As soon as they set a static IP for the service port (was DHCP and not connected) suddenly it started working.
Cisco engineer did not 'really' understand why it started working and why it only affected 1 AP, but i am just happy its fixed.  The bug report really only classifies it as a minor annoyance (in reference to the message log filling up) but in our case it actually affected functionality.  We are running the latest 7.4.130.0 FWIW
So just FYI...
Scott Fella Tue, 03/31/2015 - 18:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Old case, but at least it is coming up again.... I always look at the service port and make sure that it has a static address.  This has been an issue in the past and still is.  Always make it a best practice to define an address and you will not have to spend days or weeks chasing your tail:)
-Scott
mwright_js Fri, 11/05/2010 - 10:12
This one perplexed me too, there is no answer on Cisco's website that I could find. I think I have the  solution though....
Go to Monitor -> Interfaces -> Service-Port and have a look at the configuration.
I'm willing to bet that DHCP is enabled for the service port (the Ethernet interface on the left side of  the controller that you may or may not use) and the Ethernet is either not connected or it's connected to  a LAN where it can't get a DHCP lease.
What the controller is try trying to say is something like "%DHCP-3-BIND_SRPORT_ERR: dhcp_support.c:374 Failed to get a DHCP address for the service port"
felix.windt Thu, 11/11/2010 - 08:01
That was exactly it. Assigned a static IP instead and the error message stopped.
Thank you much!
endpoint Thu, 04/14/2011 - 07:26
Hi, thanks all for responce, As i mentioned in previous respond the issue was fixed. Stateic IP address is not solution we are looking for.
Thanks again for prompt responces.
Regards,"
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
