MGCP Gateway - Siemens
Sep 10th, 2010
Hello.
I have two PRI interfaces against a siemens platform. The gateway is configured with MGCP signaling, when i try to transfer from  PSTN - Siemens to Cisco,  i lose the call but when i transfer from Cisco to Siemens it  works.
Communication Manager 7.1.3 - Siemens Hipath 4000
Jose Luis Arango
Tim Smith Fri, 09/10/2010 - 23:21
  • Silver, 250 points or more
Hi mate..
First step I'd suggest is to check output of "debug isdn q931" on the voice gateway.
There will be a disconnect code in there.
See what it is and if it makes any sense.
When you say transfer.
Do you mean an actual call transfer?
Cheers,
Tim.
