09-11-2010 08:39 AM - edited 03-04-2019 09:44 AM
Hardware: Cisco 851 (MPC8272) processor (revision 0x300) with 59392K/6144K bytes of memory.
IOS: Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T13, RELEASE SOFTWARE (fc3)
I connected to my ISP via LAN (by DHCP) and need to establish a ppp conenction with l2tp tunnel to get to the internet.
I made all setup according to cisco documentation here http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtvoltun.html
After a successful negotiation and obtaining a WAN address tunnel stays up for a 50-60 seconds, then goes down.
Here's the debug log:
000036: *Sep 11 16:42:24.071 PCTime: %LINK-3-UPDOWN: Interface Virtual-PPP1, changed state to up
000037: *Sep 11 16:42:24.071 PCTime: Vp1 PPP: Using vpn set call direction
000038: *Sep 11 16:42:24.071 PCTime: Vp1 PPP: Treating connection as a callout
000039: *Sep 11 16:42:24.071 PCTime: Vp1 PPP: Session handle[80000002] Session id[4]
000040: *Sep 11 16:42:24.071 PCTime: Vp1 PPP: Phase is ESTABLISHING, Active Open
000041: *Sep 11 16:42:24.071 PCTime: Vp1 PPP: Authorization required
000042: *Sep 11 16:42:24.071 PCTime: Vp1 PPP: No remote authentication for call-out
000043: *Sep 11 16:42:24.071 PCTime: Vp1 LCP: O CONFREQ [Closed] id 51 len 10
000044: *Sep 11 16:42:24.071 PCTime: Vp1 LCP: MagicNumber 0xB1E0E382 (0x0506B1E0E382)
000045: *Sep 11 16:42:24.075 PCTime: L2X 00001:_____:________: APP->L2TP: Session reopen,
000046: *Sep 11 16:42:24.075 PCTime: L2X 00001:_____:________: sock 0xC8000001
000047: *Sep 11 16:42:24.075 PCTime: L2X 00001:_____:________: serv 0x00000000
000048: *Sep 11 16:42:24.075 PCTime: L2X 00001:_____:________: data 0x829ADABC[92]
000049: *Sep 11 16:42:24.075 PCTime: L2X 00001:_____:________:
000050: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: Create session
000051: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: App type set to XCONNECT
000052: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: Need cc version: V2
000053: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: Session classname beeline
000054: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: L2TPoUDP session needed between
000055: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: <unset>:0<->10.0.0.28:0
000056: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: Using ICRQ FSM
000057: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: remote ip set to 10.0.0.28
000058: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: local ip set to 10.68.183.241
000059: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: guessed local ip of 10.68.183.241
000060: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: no cookies enabled
000061: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: FSM-Sn ev App-Conn
000062: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: FSM-Sn Idle->Wt-CC
000063: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: FSM-Sn do App-Connect
000064: *Sep 11 16:42:24.075 PCTime: L2TP 00001:_____:________: Find or create cc for session
000065: *Sep 11 16:42:24.075 PCTime: L2TP _____:________: Find cc between
000066: *Sep 11 16:42:24.075 PCTime: L2TP _____:________: <unset><->10.0.0.28
000067: *Sep 11 16:42:24.075 PCTime: L2TP _____:________: with class: beeline
000068: *Sep 11 16:42:24.075 PCTime: L2TP _____:________: and IP proto: L2TPoUDP
000069: *Sep 11 16:42:24.075 PCTime: L2TP _____:________: and framing type: none
000070: *Sep 11 16:42:24.079 PCTime: L2TP _____:________: and bearer type: none
000071: *Sep 11 16:42:24.079 PCTime: L2TP _____:________: and version: V2
000072: *Sep 11 16:42:24.079 PCTime: L2TP _____:________: Need to instigate control channel
000073: *Sep 11 16:42:24.079 PCTime: L2X tnl 0100A:________: Create logical tunnel
000074: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:________: Create tunnel
000075: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:________: version set to V2
000076: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:________: remote ip set to 10.0.0.28
000077: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:________: local ip set to 10.68.183.241
000078: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:________: guessed local ip of 10.68.183.241
000079: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: class name beeline
000080: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: FSM-CC ev Session-Conn
000081: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: FSM-CC Idle->Wt-Sock
000082: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: FSM-CC do Session-Conn-Sock
000083: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: Session count now 1
000084: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: XCONNECT Session count now 1
000085: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: Session PMTU count now 1
000086: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: Open sock 10.68.183.241:1701->10.0.0.28:1701
000087: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: FSM-CC ev Sock-Ready
000088: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: FSM-CC Wt-Sock->Wt-SCCRP
000089: *Sep 11 16:42:24.079 PCTime: L2TP tnl 0100A:00001251: FSM-CC do Tx-SCCRQ
000090: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251:
000091: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: O SCCRQ to 10.0.0.28
000092: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: IETF v2:
000093: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: Protocol Version 1, Revision 0
000094: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: Framing Cap none(0x0)
000095: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: Tie Breaker
000096: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: 2573437734206683887
000097: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: Firmware Ver 0x1130
000098: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: Hostname "cisco"
000099: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: Vendor Name
000100: *Sep 11 16:42:24.083 PCTime: L2TP tnl 0100A:00001251: "Cisco Systems, Inc."
000101: *Sep 11 16:42:24.087 PCTime: L2TP tnl 0100A:00001251: Assigned Tunnel I 4689
000102: *Sep 11 16:42:24.087 PCTime: L2TP tnl 0100A:00001251: Rx Window Size 128
000103: *Sep 11 16:42:24.087 PCTime: L2TP tnl 0100A:00001251:
000104: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: Session attached
000105: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C:
000106: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: APP->L2TP: setup dataplane,
000107: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: sock 0xC8000001
000108: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: serv 0x00000000
000109: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: no serv hdl yet; use socket
000110: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C:
000111: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev DP-Setup
000112: *Sep 11 16:42:24.087 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn in Wt-CC
000113: *Sep 11 16:42:24.091 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Ignore-DP-Setup
000114: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251:
000115: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: I SCCRP, flg TLS, ver 2, len 109
000116: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: IETF v2:
000117: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: Protocol Version 1, Revision 0
000118: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: Framing Cap none(0x0)
000119: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: Firmware Ver 0x1130
000120: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: Hostname "ar0-co25.zp.fttb"
000121: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: Vendor Name
000122: *Sep 11 16:42:24.091 PCTime: L2TP tnl 0100A:00001251: "Cisco Systems, Inc."
000123: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: Assigned Tunnel I 36720
000124: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: Rx Window Size 1024
000125: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251:
000126: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: I SCCRP from ar0-co25.zp.fttb
000127: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: FSM-CC ev Rx-SCCRP
000128: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: FSM-CC Wt-SCCRP->Proc-SCCRP
000129: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: FSM-CC do Rx-SCCRP
000130: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: FSM-CC ev SCCRP-OK
000131: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: FSM-CC Proc-SCCRP->established
000132: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: FSM-CC do Tx-SCCCN
000133: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251:
000134: *Sep 11 16:42:24.095 PCTime: L2TP tnl 0100A:00001251: O SCCCN to ar0-co25.zp.fttb tnl 36720
000135: *Sep 11 16:42:24.099 PCTime: L2TP tnl 0100A:00001251:
000136: *Sep 11 16:42:24.099 PCTime: L2TP tnl 0100A:00001251: Control channel up
000137: *Sep 11 16:42:24.099 PCTime: L2TP tnl 0100A:00001251: 10.68.183.241<->10.0.0.28
000138: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev CC-Up
000139: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn Wt-CC->Wt-Sock
000140: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do CC-Up
000141: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: Session needs to have:
000142: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: V2 V3 Eth VLAN HDLC PPP FR-DLCI
000143: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: ATM-PORT ATM-VP ATM-VC-CELL IP
000144: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: Tie-Breaker
000145: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: Peer cc can do:
000146: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: V2 Tie-Breaker
000147: *Sep 11 16:42:24.099 PCTime: L2TP 00001:0100A:0000000C: Open sock 10.68.183.241:1701->10.0.0.28:1701
000148: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Sock-Ready
000149: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn Wt-Sock->Wt-Tx-ICRQ
000150: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Tx-ICRQ-Local-Check
000151: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Local-Cont
000152: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn Wt-Tx-ICRQ->Wt-Rx-ICRP
000153: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Tx-ICRQ
000154: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C:
000155: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: O ICRQ to ar0-co25.zp.fttb 36720/0
000156: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: IETF v2:
000157: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: Assigned Call ID 12
000158: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C: Serial Number 52641
000159: *Sep 11 16:42:24.103 PCTime: L2TP 00001:0100A:0000000C:
000160: *Sep 11 16:42:24.107 PCTime: L2TP tnl 0100A:00001251: I ZLB ACK, flg TLS, ver 2, len 12
000161: *Sep 11 16:42:24.107 PCTime: L2TP tnl 0100A:00001251:
000162: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: I ICRP, flg TLS, ver 2, len 28
000163: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: IETF v2:
000164: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: Assigned Call ID 47223
000165: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C:
000166: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Rx-ICRP
000167: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn Wt-Rx-ICRP->Proc-ICRP
000168: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Rx-ICRP
000169: *Sep 11 16:42:24.107 PCTime: L2TP 00001:0100A:0000000C: MTU is 65535
000170: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: Session data plane UP
000171: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: Remote AC is now UP
000172: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C:
000173: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: APP<-L2TP: remote circuit status
000174: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: sock 0xC8000001
000175: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: serv 0x00001000
000176: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: UP
000177: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C:
000178: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: XCONNECT: process AVPs
000179: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C:
000180: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: APP<-L2TP: connecting
000181: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: sock 0xC8000001
000182: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C: serv 0x00001000
000183: *Sep 11 16:42:24.111 PCTime: L2TP 00001:0100A:0000000C:
000184: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Local-Up
000185: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn in Proc-ICRP
000186: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Noop-Local-State-Change
000187: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C:
000188: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: APP->L2TP: connect cont,
000189: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: sock 0xC8000001
000190: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: serv 0x00001000
000191: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: replied on same socket
000192: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C:
000193: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev ICRP-OK
000194: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn Proc-ICRP->Wt-Tx-ICCN
000195: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Tx-ICCN-Local-Check
000196: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Local-Cont
000197: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn Wt-Tx-ICCN->established
000198: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Tx-ICCN
000199: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C:
000200: *Sep 11 16:42:24.115 PCTime: L2TP 00001:0100A:0000000C: APP<-L2TP: connected
000201: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C: sock 0xC8000001
000202: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C: serv 0x00001000
000203: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C:
000204: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C: O ICCN to ar0-co25.zp.fttb 36720/47223
000205: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C: IETF v2:
000206: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C: Framing Type none(0)
000207: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C: Connect Speed 0
000208: *Sep 11 16:42:24.119 PCTime: L2TP 00001:0100A:0000000C:
000209: *Sep 11 16:42:24.123 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Established
000210: *Sep 11 16:42:24.123 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn in established
000211: *Sep 11 16:42:24.123 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Established
000212: *Sep 11 16:42:24.123 PCTime: L2TP 00001:0100A:0000000C: Session up
000213: *Sep 11 16:42:24.123 PCTime: L2TP 00001:0100A:0000000C: 10.68.183.241<->10.0.0.28
000214: *Sep 11 16:42:24.123 PCTime: L2TP tnl 0100A:00001251:
000215: *Sep 11 16:42:24.123 PCTime: L2TP tnl 0100A:00001251: I ZLB ACK, flg TLS, ver 2, len 12
000216: *Sep 11 16:42:24.123 PCTime: L2TP tnl 0100A:00001251:
000217: *Sep 11 16:42:24.123 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn ev Local-Up
000218: *Sep 11 16:42:24.127 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn in established
000219: *Sep 11 16:42:24.127 PCTime: L2TP 00001:0100A:0000000C: FSM-Sn do Tx-SLI
000220: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: Timeout: State REQsent
000221: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: O CONFREQ [REQsent] id 52 len 10
000222: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: MagicNumber 0xB1E0E382 (0x0506B1E0E382)
000223: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: I CONFREQ [REQsent] id 1 len 19
000224: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: MRU 1460 (0x010405B4)
000225: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: AuthProto CHAP (0x0305C22305)
000226: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: MagicNumber 0xE8A9B341 (0x0506E8A9B341)
000227: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: O CONFNAK [REQsent] id 1 len 8
000228: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: MRU 1500 (0x010405DC)
000229: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: I CONFACK [REQsent] id 52 len 10
000230: *Sep 11 16:42:26.079 PCTime: Vp1 LCP: MagicNumber 0xB1E0E382 (0x0506B1E0E382)
000231: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: I CONFREQ [ACKrcvd] id 2 len 19
000232: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: MRU 1500 (0x010405DC)
000233: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: AuthProto CHAP (0x0305C22305)
000234: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: MagicNumber 0xE8A9B341 (0x0506E8A9B341)
000235: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: O CONFACK [ACKrcvd] id 2 len 19
000236: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: MRU 1500 (0x010405DC)
000237: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: AuthProto CHAP (0x0305C22305)
000238: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: MagicNumber 0xE8A9B341 (0x0506E8A9B341)
000239: *Sep 11 16:42:26.087 PCTime: Vp1 LCP: State is Open
000240: *Sep 11 16:42:26.087 PCTime: Vp1 PPP: No authorization without authentication
000241: *Sep 11 16:42:26.087 PCTime: Vp1 PPP: Phase is AUTHENTICATING, by the peer
000242: *Sep 11 16:42:26.119 PCTime: Vp1 CHAP: I CHALLENGE id 1 len 37 from "ar0-co25.zp.fttb"
000243: *Sep 11 16:42:26.119 PCTime: Vp1 CHAP: Using hostname from interface CHAP
000244: *Sep 11 16:42:26.119 PCTime: Vp1 CHAP: Using password from interface CHAP
000245: *Sep 11 16:42:26.119 PCTime: Vp1 CHAP: O RESPONSE id 1 len 31 from "0003803100"
000246: *Sep 11 16:42:26.207 PCTime: Vp1 CHAP: I SUCCESS id 1 len 4
000247: *Sep 11 16:42:26.207 PCTime: Vp1 PPP: Phase is FORWARDING, Attempting Forward
000248: *Sep 11 16:42:26.207 PCTime: Vp1 PPP: Queue IPCP code[1] id[1]
000249: *Sep 11 16:42:26.207 PCTime: Vp1 PPP: Phase is ESTABLISHING, Finish LCP
000250: *Sep 11 16:42:26.211 PCTime: Vp1 PPP: Phase is UP
000251: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: O CONFREQ [Closed] id 1 len 10
000252: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: Address 0.0.0.0 (0x030600000000)
000253: *Sep 11 16:42:26.211 PCTime: Vp1 PPP: Process pending ncp packets
000254: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: Redirect packet to Vp1
000255: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: I CONFREQ [REQsent] id 1 len 10
000256: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: Address 94.27.126.8 (0x03065E1B7E08)
000257: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: O CONFACK [REQsent] id 1 len 10
000258: *Sep 11 16:42:26.211 PCTime: Vp1 IPCP: Address 94.27.126.8 (0x03065E1B7E08)
000259: *Sep 11 16:42:26.215 PCTime: Vp1 IPCP: I CONFNAK [ACKsent] id 1 len 10
000260: *Sep 11 16:42:26.215 PCTime: Vp1 IPCP: Address 46.118.76.217 (0x03062E764CD9)
000261: *Sep 11 16:42:26.215 PCTime: Vp1 IPCP: O CONFREQ [ACKsent] id 2 len 10
000262: *Sep 11 16:42:26.219 PCTime: Vp1 IPCP: Address 46.118.76.217 (0x03062E764CD9)
000263: *Sep 11 16:42:26.223 PCTime: Vp1 IPCP: I CONFACK [ACKsent] id 2 len 10
000264: *Sep 11 16:42:26.223 PCTime: Vp1 IPCP: Address 46.118.76.217 (0x03062E764CD9)
000265: *Sep 11 16:42:26.223 PCTime: Vp1 IPCP: State is Open
000266: *Sep 11 16:42:26.223 PCTime: Vp1 IPCP: Install negotiated IP interface address 46.118.76.217
000267: *Sep 11 16:42:26.227 PCTime: Vp1 IPCP: Install route to 94.27.126.8
000268: *Sep 11 16:42:27.207 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-PPP1, changed state to up
000270: *Sep 11 16:43:18.430 PCTime: Vp1 PPP: Missed 5 keepalives, taking LCP down
000271: *Sep 11 16:43:18.430 PCTime: Vp1 PPP: Sending Acct Event[Down] id[5]
000272: *Sep 11 16:43:18.430 PCTime: Vp1 LCP: State is Closed
000273: *Sep 11 16:43:18.430 PCTime: Vp1 PPP: Phase is DOWN
000274: *Sep 11 16:43:18.430 PCTime: Vp1 IPCP: State is Closed
000275: *Sep 11 16:43:18.430 PCTime: Vp1 PPP: Phase is ESTABLISHING, Passive Open
000276: *Sep 11 16:43:18.430 PCTime: Vp1 LCP: State is Listen
000277: *Sep 11 16:43:18.438 PCTime: Vp1 IPCP: Remove route to 94.27.126.8
000278: *Sep 11 16:43:19.430 PCTime: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-PPP1, changed state to down
After interface goes down I can't ever ping my provider local network hosts (10.x.x.x), including gateway, dns servers and BRAS, until disabling Virtual-PPP1 interface and making "shut/no shut" operation on WAN interface (FastEthernet4).
What I have missed?
My config:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 *****************************
no aaa new-model
clock timezone PCTime 2
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 4:00
crypto pki trustpoint TP-self-signed-2208831923
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2208831923
revocation-check none
rsakeypair TP-self-signed-2208831923
crypto pki certificate chain TP-self-signed-2208831923
certificate self-signed 01 nvram:IOS-Self-Sig#25.cer
dot11 syslog
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.121 192.168.1.254
ip dhcp pool Home-LAN
import all
network 192.168.1.0 255.255.255.0
lease infinite
ip cef
ip domain name internet.beeline.ua
l2tp-class beeline
username max privilege 15 secret 5 *********************
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
pseudowire-class pwc1
encapsulation l2tpv2
protocol l2tpv2 beeline
ip local interface FastEthernet4
ip pmtu
ip dfbit set
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
ip address dhcp
duplex auto
speed auto
interface Virtual-PPP1
ip address negotiated
no cdp enable
ppp authentication chap callin
ppp chap hostname 0003803100
ppp chap password 7 ******************
pseudowire 10.0.0.28 1 pw-class pwc1
interface Vlan1
ip address 192.168.1.254 255.255.255.0
no ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging 192.168.1.2
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
banner login CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
09-11-2010 08:51 AM
Your logging states it:
On Cisco Routers, keepalive default is 10 Seconds.
After 5 missed keepalive-answers, the link is declared dead.
5 x 10 sec = 50 sec, your ca minute.
For allmost all ADSL Connections, typical Telco keepalive time is 30 seconds.
If you can check with the other side,
they should check
a) your radius-profile for a keepalive statement
b) the virtual-template for the default value.
If you cannt check, try:
c)
conf t
keep 30
end
or
d)
conf t
no keep
end
d) means no keepalive checking so your router will think after initial connection it's allways logged in even when the remote-side
clears your session (probably, you get this signalled by l2tp).
Hope this help's,
Juergen.
09-11-2010 09:36 AM
Already tried keepalive option, with no success.
Keepalives loss is just an indication of something wrong with routes/cef as far as i understand.
I forgot to mention that the same L2TP connection from my computer with Windows (connected to ISP) works well.
Also already tried no peer neighbor-route, no ip route-cache cef, setting routes manually
ip route 0.0.0.0 0.0.0.0 Virtual-PPP1
ip route 10.0.0.28 255.255.255.255 dhcp
ip route 10.10.14.2 255.255.255.255 dhcp
still fail.
09-11-2010 09:52 AM
I have found something similar here - http://www.velocityreviews.com/forums/t379750-p3-cisco-1721-as-pptp-client.html
"Any packets sent into the vpn will disappear into a black hole because of the routing loop created by using the same address for the server's end of the PPP link and the initiate-to. That's what is killing the vpn by blocking the keepalives."
Maybe it's the cause?
09-11-2010 12:27 PM
that sound liek a good explanation for the scenario.
So you must construct either a ip local policy route-map
to fix this - may be a problem with dynamic "Internet" ip,
or put the different layers into differnet routing clouds "vrf"s to solve that problem.
Juergen.
09-11-2010 01:05 PM
Can you please provide an example? I'm new to cisco routers, just started to learn IOS concepts.
09-11-2010 02:00 PM
the l2tp traffic is global, your int fas 4 dhcp connection.
the vlan1 and ppp interface go to the routing-table "home"
So you can easily have for both just the default-route without
having to differate them or write magic policy maps:
conf t
ip vrf home
rd 65535:20
route-target both 65535:20
int virt-ppp 1
ip vrf forwarding home
! entering this deletes configured ip address, so configure it again
int vlan 1
! oops you was telnetting thru this interface.
! good old serial light-blue cable
ip route vrf home 0.0.0.0 0.0.0.0 virt-ppp 1
end
CLI-Commands let you select the right routing-cloud:
"show ip route vrf home"
"ping vrf home 1.2.3.4"
"telnet 1.2.3.4 /vrf home"
hope this helps,
Juergen.
09-11-2010 03:08 PM
Unfortunately, cisco 851 does not recognize ip vrf syntax.
09-13-2010 08:47 AM
Now i have set up a 881 out of the box (behind nat internet router).
( universal-data-12.4(15)XZ image )
Central side is currently a 7206vxr-npe300, with the latest/last possible ios.
My sessions get closed after 2:40 which fits the configured keepalive of 30 seconds.
Or is it a nat timeout on the device in-between ?
In the meantime, there is only going very few traffic beetween them (1 or 2 "ping" work, then fini)
(independent of vrf or not).
I suspect my central side since that device has shut off CEF due to low memory.
I will setup hmmm. wednesday a 1812 to have a "fresh" central side.
Juergen..
09-13-2010 09:13 AM
just moved the config to the nat-router in front of the 881 (a cisco 1803, 12.4(15T2) )
so that nat is not the factor: no change, session down after <3 min because of 5 lost keepalives
(routing with overlapping ip addresses is not the case here).
Since the "central side" is quite old and i set up the l2tp function here to have a quick start,
i believe i must change this device first.
Juergen.
09-21-2010 04:42 AM
So, i did set up my "central side" .
When the virtual-template uses the same (loopback) adress as the l2tp does,
(and the cpe, here: 881) does _not_ have a vrf as shown,
i also get the missed keepalive and session-shutdown.
With a vrf for the "inside" LAN everything works fine.
Also with "no peer neighbro route" and some special route it works.
looking thru software advisor...looks like no vrf support for 851 .
Strange, even a soho96 had it in 12.3(14)T7 .
Here is what i have configured:
! Cisco 881 C880DATA-UNIVERSALK9-M Version 12.4(15)XZ
! ROUTE version
ip cef
vpdn enable
l2tp-class l2tpc1
authentication
hostname TUNNEL-CLIENT
password TUNNEL-CLIENT-PASSWORD
protocol l2tpv2 l2tpc1
ip pmtu
ip tos reflect
ip address dhcp
duplex auto
speed auto
no shutdown
interface Loopback0
ip address 222.333.444.555 255.255.255.255
no shutdown
ip unnumbered Loopback0
no cdp enable
ppp authentication pap chap callin
ppp chap hostname WINNIE@POOH
ppp chap password TIGGER
ppp pap sent-username WINNIE@POOH password TIGGER
pseudowire 999.888.777.666 1 pw-class pwc1
no shutdown
ip route 999.888.777.666 255.255.255.255 dhcp
interface Vlan1
! ip address ...
end
And here is the vrf version:
! VRF Version
ip cef
vpdn enable
ip vrf home
rd 65535:20
route-target export 65535:20
route-target import 65535:20
l2tp-class l2tpc1
authentication
ip pmtu
ip tos reflect
ip address dhcp
duplex auto
speed auto
no shutdown
ip pmtu
ip tos reflect
interface Loopback0
no shutdown
no cdp enable
no shutdown
ip route vrf home 0.0.0.0 0.0.0.0 Virtual-PPP1
interface Vlan1
! ip address ...
end
Finally, relevant LNS and radius-profile:
! LNS
ip cef
vpdn enable
vpdn source-ip 999.888.777.666
vpdn search-order domain
vpdn domain-delimiter @ suffix
vpdn-group 99
accept-dialin
protocol l2tp
virtual-template 99
terminate-from hostname TUNNEL-CLIENT
local name TUNNEL-SERVER
lcp renegotiation always
l2tp tunnel password TUNNEL-CLIENT-PASSWORD
l2tp tunnel receive-window 256
interface Loopback0
ip address 999.888.777.666 255.255.255.255
no shutdown
! connection to internet not shown
interface Virtual-Template99
ip verify unicast reverse-path
ppp multilink
aaa new-model
aaa authentication ppp default group radius
aaa nas port extended
aaa session-id common
radius-server host 111.999.111.999 auth-port 1812 acct-port 1813 non-standard key ROADRUNNER
end
! Radius profile
WINNIE@POOH Password = "TIGGER", Service-Type = Framed-User
Framed-Protocol = PPP,
Framed-IP-Address = 222.333.444.555,
Framed-IP-Netmask = 255.255.255.255,
Framed-Routing = None
! THE END
The mistake here is that the IP-Adress for the virtual-template is the same as the IP-Adress used for bulding the L2TP Tunnel,
which leads to the disconnection after approx. 5x keepalive = 50 seconds,
which may be corrected by "no peer neighbor route" and explicit route for the LNSes IP-Address.
Configuring an LNS in this way is not recommended and should be avoided.
Allways seperate tunnel-feet and user-traffic thru tunnel - it is irrelevant wether it's a GRE- L2Tp or IPSEC- tunnel.
If you have just a handfull (and not the default) route to go thru the l2tp/virtual-ppp interface,
static routes for
Seperating both worlds using VRF is an elegant solution for this problem.
Hope this help's,
Jürgen.
09-22-2010 05:39 AM
Though all my efforts in configuring are still unsuccessful I am very glad for your responses and appreciate your work on diagnostics.
