How to eliminate T302 timer on FAC entry
Sep 11th, 2010
CallManager 7.1 using Forced Authorization Codes - when users dial numbers matching route patterns which require FAC entry -
after the user enters the FAC the system waits for T302 to expire before routing call or requires #.
All of our FAC are always 8 digits long by design. Since they are always 8 digits long is there a way to avoid the T302 timer so calls either route or deny as soon as 8 digits are entered by the user?
thanks,
rick
kusatija Sun, 09/12/2010 - 10:32
  • Silver, 250 points or more
Hi Rick,
I do not believe currently there is any other option other than reducing the t302 timer, while using FAC...
If you use FAC, call manager will wait for the inter digit timeout, all you can to is reduce this timer..
Kunal
Related Content
