Cisco switch IOS migration from SXD featureset to SXF
I have cisco 6513 Switch running s72033-psv-mz.122-18.SXD7b.bin. I  could find bug CSCei28317 is hitting in currrent version. Fixed-in version available in  SXF train.
The challenge i face is SXD7b same featureset is not available  in SXF train to migrate it. What would be recommended featureset train from SXD  to SXF.
Please suggest suitable feature set to upgrade.
Jon Marshall Sun, 09/12/2010 - 04:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You need to use Feature Navigator for this sort of thing. Within Feature Navigator there is an option to compare 2 images so you can select your current IOS/feature set and then the one you to migrate to and see the differences in features etc.  SXF is quite old now, don't rule out looking at SXH or SXI for the 6500 switch as well -
Feature Navigator
Jon
