EIGRP network command
Answered Question
I have two routers on EIGRP
172.16.1.1(lo)---->R1(F0/0 192.168.1.1/24)<------------->(F0/0 192.1681.2/24)R2<-----10.10.1.1/24
172.16.2.1(l0)        <----10.10.2.0/24
R1
Routing for Networks:
    172.16.0.0
    192.168.1.1/32
R2
    10.10.0.0/16    <--------specified wildcard mask
    192.168.1.0
I have now eigrp running and all neighbours are formed....but with following routing table
R1
D       172.16.0.0/16 is a summary, 00:42:30, Null0
C       172.16.1.0/24 is directly connected, Loopback1
C       172.16.2.0/24 is directly connected, Loopback2
D    10.0.0.0/8 [90/156160] via 192.168.1.2, 00:42:25, FastEthernet0/0   <--------shouldn't this be 10.10.0.0/16?
C    192.168.1.0/24 is directly connected, FastEthernet0/0
R2
D    172.16.0.0/16 [90/156160] via 192.168.1.1, 00:42:55, FastEthernet0/0
     10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C       10.10.1.0/24 is directly connected, Loopback1
C       10.10.2.0/24 is directly connected, Loopback2
D       10.0.0.0/8 is a summary, 00:52:02, Null0
why int R1 we have
Need your help in understanding this. Thanks
Correct Answer by milan.kulik about 6 years 8 months ago
you need
router eigrp xxx
no auto-summary
command in your configs.
See http://www.cisco.com/en/US/customer/docs/ios/iproute_eigrp/configuration/guide/ire_cfg_eigrp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1060541
for an example.
HTH,
Milan
Message was edited by: milan.kulik
Overall Rating: 5 (1 ratings)
suryakant.chavan Sun, 09/12/2010 - 11:39
Hi Ravindra,
If you want to see the entry  10.10.0.0/16 under R1 then you should give the command no auto-summary under R2 .
that is
          Router eigrp As
          network 10.10.0.0 0.0.255.255
          no auto-summary.
Because though EIGRP is class less routing protocol , its default behaviour is classfull . If we have not given no auto-summary command  , it summaries its directly connected networks to their default class & advertise to their neighbour.
Hope this is helpful to you.
Suryakant
So if i am not wrong. There are two things that a network command does
1> checks the interfaces within the defined Network command
2> advertises all networks/routes on those interfaces which come in the defined network command
3> if in the network command, even after adding the subnet mask it will round it to classful network [need your comments as cisco official guide says
If no wildcard mask is configured on the eigrp network command, the command enables EIGRP on all of that routes directly connected to the configured classful network]
4> to have the routes in particular subnet we have to use no auto-summary as router sub command
Giuseppe Larosa Sun, 09/12/2010 - 12:26
  • Hall of Fame,
    Founding Member
Hello Ravindra,
the EIGRP network command does not provide an aggregate address "automatically" matching the network command itself.
in your example you have network 10.10.0.0 0.0.255.255 but this only means that all interfaces whose IP address falls in 10.10.0.0/16 will have the associated IP subnet advertised and they will be able to build EIGRP neighborships.
with no auto-summary set on  router eigrp process you will see the IP subnets 10.10.1.0/24 and 10.10.2.0/24 and not 10.10.0.0/16
To see 10.10.0.0/16 you need to use the ip summary-address eigrp command in interface mode AND you need no auto-summary
Hope to help
Giuseppe
